dknovick
NM, USA Status: offline
quote:
ORIGINAL: helojerry Exactly! I don't believe that pot is meant to adjust trim at all. I think that it adjusts rate feedback gain, which is consistent with your measurement. Rate feedback does not help with trim offsets, only with transient response. Evidently, on the F40, the tab on the transmitter is the only means of trimming SS yaw rate. I checked rate feedback gain again last night. If it does change it, it's not by much. I certainly didn't see a 30% difference in the output to the tail as I rocked the board back and forth when I set the pot from 0.5V to 3V. I'll play more this weekend and see what shakes out... quote:
Ah ha! I saw those guys in your photo and wondered about that. It was the only thing I could figure they would be used for. Good catch! Can you enlighten me on what some of the other parts are? I'm not so familiar with SM parts as you are I'm sure. I was trying to figure out where the RF section is etc yesterday. I thought they might have been, but I never sat down and checked to see where they where exactly connected. I'm sure you know some of this, but for the other: Small black things are resistors (3 numbers correspond to the value, 333 = 33x10^3 = 33k), small tan things are caps. The small black things with three pins (one on one side, two on the other) are either NPN or PNP transistors. RF is still black magic to me... However on the first picture, the 31136G chip is an FM single conversion receiver IC (I still haven't found a datasheet for it yet). Second picture, working left from the crystal socket (with is in the bottom right): CFWM 455E is a Piezo filter (455 kHz band pass), and I *believe* the aluminum box is a tuning coil for the antenna. -Dave
_____________________________
What goes up, most come down. How hard depends on you!
