dknovick
NM, USA Status: offline
quote:
ORIGINAL: helojerry I've been wanting to write more about the yaw ratre gyro, but haven't had the time. In my thinking, "gain" and "proportional" mean the same think. If I write y=kx it means that "y is directly proportional to x" and we could say the k is the proportionality factor or "gain." True, but I believe that UTM was referring to changing the gain on the gyro input as opposed to adding more offset to the tail. Based on my (and others) observations, the tail is controlled by this equations: tail = k1*main_motor + k2*gyro + offset where: k1 = proportional gain from the main_motor (most likely less then 1) k2 = proportional gain from the gyro offset = user input (from the trim tab) to stabilize the yaw (keep the nose pointing straight with "hands-off" ) (this is assuming that it's just P control and not PID [Proportional, Integral, Derivative], or PI, or PD ) or even Fuzzy Logic! So the question is, does the pot change the "offset", or "k2" quote:
ORIGINAL: helojerry One of the things that makes it so difficult to figure out what is really going on with these pot settings is that there are so many variables to consider. To start with, every helicopter is going to behave somewhat differently right from the factory because of the level of quality control applied to a mass produced item like the F40. Then add on top of that the mods, repairs, and fixes that are being applied to these things by the owners and we have lots of variation and variables to consider eg. batteries, motors, tail booms, winds, density altitude and more! I know Dave has done a bunch of work trying to get a handle on this adjustment pot and I really appreciate all that he has done. Dave is concluding that the pot does not seem to have any effect on tail rotor speed or on how the bird flies and that may be entirely correct. On the other hand, especially in view of the other variables that have to be considered, this is a very difficult determination to make. I'm guessing the pot is suppose to do something. You don't add a component to the board if it's not going to be used (it's just a waste of money). I'm leaning towards it adjusting "k2", since I didn't see much of a difference in the "offset" on the o-scope when I adjusted it. Of course, I didn't see much of a difference with either setting. Maybe there's something wiggy with my 4in1. The next one I fix, I'll check that one out as well.
_____________________________
What goes up, most come down. How hard depends on you!
