robotronski -> RE: Falcon 40 (Exceed heli) Forum (10/25/2006 2:06:49 AM)
quote:
ORIGINAL: oblakmd Hi everyone. I fried my charger. I am looking for a replacement and I found robotronski's post for the Smart Univresal Battery Charger. I do not understand that the if the stock battery is 650 mAh and the charger is for batteries 1100 or over, then what will it do to the battery? If this is not what I need, then what? If it just decreases the battery life, then no biggie. Oh, another thing...would charging 2 battery packs in parallel make the mAh 1300? Thanks Mitch Not to worry, all the 1100 number means is that it is capable of putting out 1100mA of charge if needed. It will have no problem charging a smaller 650mAH pack. Where did you see that number ? 1100ma?? You are talking about the Tenergy Ni-Cd/NiMh universal charger? I use the same charger for my RC trucks and they have 3300maH NiMh packs. It does a good job on those too, just takes a bit longer to top off the battery to peak volts, thats all. My charger has a switch that sets charge current to either 900mA or 1800mA. I use 900mA setting for my heli packs. Its the charge current that makes the battery warm during charging. If you continue to apply current after it is "Full" the current produces excess heat. The smart charger senses the "Full" state of charge and shuts off the charging current supply, then lights up the green LED. You won't cook your stock650maH battery with that charger. With the provided alligator clips, I use it to charge cordless drills and all sorts of household gadgets. The charge light is red when charging and green when ready. Green means go fly !!!! Not sure about charging 2 packs in parallel. Risky if one pack hogs all the current (internal resistance not the same) Not sure how the smart charger would react to such a condition... Hope I was some help to ya'
