RE: Falcon 40 (Exceed heli) Forum    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Falcon 40 (Exceed heli) Forum
Page: <<   < prev  376 377 378 379 380 381 382 383 384 [385]
Login
RE: Falcon 40 (Exceed heli) Forum - 1/5/2012 2:21 AM
dknovick
Score: 113
Last Login: 5/7/2013
Status: offline
quote:
ORIGINAL: stalledout
Looking up flybar mod, found it, .078 music wire, or 2mm carbon. 175mm long. Just broke mine tonight, I do have a spare frame I can take one off of, but will see if I have any .078 music wire around.
That sounds about right. If you don't have any around, try a local hobby or arts & crafts store.
-Dave
_____________________________
Helicopter: Closest fulfillment of the flying horse and magic carpet. Igor Sikorsky
Royal EVO9 TX/F40,HBFP,Trex450Sport
Hide Signatures
(in reply to stalledout)
       Post #: 9601
RE: Falcon 40 (Exceed heli) Forum - 1/6/2012 5:17 AM
stalledout
Score: 100
Last Login: 1/28/2013
Status: offline
I ended up creating a flybar rod from a used bike spoke.
My heli always wants to go left. When I was repairing it, I noticed that one servo was set so the swashplate was not level, the left side was higher (looking from the back of the heli, or as if you were sitting in the heli). I adjusted the servo arm so the swashplate was level and then flew the heli. Now the heli always wants to go to the left unless I have the right stick all the way to the right. I think I had previously adjusted the swashplate/servo to get rid of this left turning tendency. Any suggestions?
Thanks.
Hide Signatures
(in reply to dknovick)
       Post #: 9602
RE: Falcon 40 (Exceed heli) Forum - 1/16/2012 3:28 PM
EAGLE47
Score: 100
Last Login: 1/17/2012
Status: offline
I have an Exceed Falcon 40 v1 that does nothing.  I have charged the batteries, checked the crystals, and checked the antenna.  It worked for a a minute or two and stopped working abruptly. The servos come to life when the battery is connected.  It acts like it is not getting any signal.   It is either the transmitter or receiver.  Is this a normal problem for this model.  It appears that it is hard to purchase the transmitter and receiver, so I am assuming there are others witht he same issue.  Is there another transmitter / receiver set up I can purchase that would work?
Hide Signatures
(in reply to robotronski)
       Post #: 9603
RE: Falcon 40 (Exceed heli) Forum - 1/16/2012 5:17 PM
GTX SlotCar
Score: 122
Last Login: 2/9/2012
Status: offline
You have to let the Rx (receiver) arm itself and there's a safety feature. Try this:
1. You have to make sure the Transmitter throttle and throttle trim lever are all the way down (that's the safety feature).
2. Turn on the Tx (transmitter).
3. Plug in the helicopter batter.
After a couple seconds the servos should make a quick move as they arm. After that the Tx and heli should work OK.
Gary
SuperSkids®
Hide Signatures
       Post #: 9604
RE: Falcon 40 (Exceed heli) Forum - 1/16/2012 7:31 PM
dknovick
Score: 113
Status: offline
Cool!
Thanks.
So, you're heli was going to the left, you adjusted it (from what you could tell), and it still goes left. Let's see:
1) Did you adjust the servos when then where on, and in the neural position? (unplug the main motor, so you don't turn it on by mistake).
2) How did you adjust the servo arms?
3) Double check that nothing else is broken. You may have a broken part that causing the heli to go to the left.
4) Double check the balance. Make sure it doesn't lean to the left.
-Dave
Hide Signatures
       Post #: 9605
RE: Falcon 40 (Exceed heli) Forum - 1/16/2012 7:34 PM
dknovick
Score: 113
Status: offline
quote:
ORIGINAL: EAGLE47
...to add to what Gary said...
Make sure you haven't flipped a switch to invert the transmitter, so that stop (full down), is now full on. In which case, it won't arm.
The servos turn on, so there's power getting to the 4in1. What is the led doing? Slow blink, fast blink, no blink...?
Hide Signatures
(in reply to EAGLE47)
       Post #: 9606
RE: Falcon 40 (Exceed heli) Forum - 3/7/2012 2:31 PM
fz1speedrider
Score: 100
Last Login: 4/9/2012
Status: offline
hey i hae a new falcon 40 v2  have any of u guys tweaked the gyro at all ?   it flies ok   but its a little tempramental   the nose moves around and stuff we have trimmed it and its a little better  but i ve heard that the tail ruddr is a little unresponsive and i thought about tweaking the gyro to be more responsive.. where can i go to find out exactly about the trim settings on the radio control and gyro settings for this heli...is there a website dedicated for this heli? any help would be apreciated.
Hide Signatures
       Post #: 9607
RE: Falcon 40 (Exceed heli) Forum - 3/11/2012 10:37 PM
dknovick
Score: 113
Status: offline
quote:
ORIGINAL: fz1speedrider
This is probably the best place to go for answers...
You can try, various people have had various results. The screw adjustment changes the gain (or at least should) on the tail. More gain will help the tail better "lock on". Too much, and the tail will "seek" (wag back and forth) while it's just hovering.
-Dave
Hide Signatures
(in reply to fz1speedrider)
       Post #: 9608
RE: Falcon 40 (Exceed heli) Forum - 9/17/2012 3:27 AM
robotronski
Score: 100
Last Login: 10/17/2012
Status: offline
Wow, you guys have really kept this thread alive and active!!!! And yes, I still have my Falcon 40's. Don't fly them too much but they really helped me get a grip on my nose in flight orientation without getting too chicken to try it. As of today, only one has officially died, I gave it to a local kid and it lasted exactly one day. He roasted the motor controller when he dug it in I guess. Even the transmitter antenna broke off!!!! I have been flying 450 size helis for a while. Not really a wild 3D pilot to be honest, mostly enjoy fast forward flight and the occasional loop. I am in the process of finishing an electric 500 size scale ship (Sikorsky Sea King in 1960's US Navy color scheme) Will have 2 radios as the 2nd radio/pilot works the door mechanism and hoist winch along with lighting circuits. Hope all of you are having fun out there .... Later, Robo
Take-offs are Optional... Last time I checked, those #%&@ landings are still Mandatory!!!
Hide Signatures
       Post #: 9609
RE: Falcon 40 (Exceed heli) Forum - 9/17/2012 3:32 AM
robotronski
Score: 100
Status: offline
Btw , if you want a fun tiny heli, look up the WL Toys V911, it has an awesome gyro and the tail really stays put. Can fly it somewhat in mild wind with full forward trim. About 50 bucks everywhere. I got one as a gift and love it.
< Message edited by robotronski -- 9/17/2012 4:22 AM >
Hide Signatures
       Post #: 9610
RE: Falcon 40 (Exceed heli) Forum - 9/22/2012 2:38 AM
dknovick
Score: 113
Status: offline
quote:
ORIGINAL: robotronski
We do what we can. Most of us have graduated to a CP heli of some sort, but still hold the F40 near and dear.
Thanks for the heads up on the WL Toys V911
-Dave
Hide Signatures
       Post #: 9611
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
