Why Triton needs 13 Amps to charge 5 amps??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Why Triton needs 13 Amps to charge 5 amps??
Page: [1]
Login
Why Triton needs 13 Amps to charge 5 amps?? - 1/15/2003 9:02:30 AM
J-3
Status: online
I don't understand why it needs so much more than the 5 amps max it can charge?
Anybody?
...Brian
       Post #: 1
Volts times Amps = Watts - 1/15/2003 9:42:34 AM
DMcQuinn
Status: offline
If the input is 12 volts and it draws 13 amps from the charging source, then is is using 156 watts of power. It can convert this to 156 amps at one volt or one amp at 156 volts.
So in order to charge a high voltage battery pack (say 15 cells) it needs to generate about 22 volts and at that voltage the 156 watts of power it is drawing could be converted to only 7 amps of current. So it is drawing 13 amps and generating 7 amps (but at a higher voltage).
Plus there are lots of losses (in the form of heat) when converting electrical energy. So some of the input energy is wasted.
(in reply to J-3)
       Post #: 2
Why Triton needs 13 Amps to charge 5 amps?? - 1/15/2003 6:20:09 PM
Red Scholefield
Status: offline
It does not need 13 amps. The maximum power it can provide on charge is 90 watts and this is for 18 volts output. Assuming 80% effeciency this would require 112 watts input or 8.6 amps at a 13 volt input.
Unless you are charging large number of cells even a 5 Amp supply will take care of most of your needs.
_____________________________
Red S.
AMA 951 Leader Member
Disclaimer: What I have written here are my thoughts and in no manner shape or form reflect the views of RCU
(in reply to J-3)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU3
