BobGeezer
Joined: 7/27/2007 From: SouthamptonHampshire, UNITED KINGDOM Status: offline
Hi Mark, Good to see your level of detail. It gives me something to aim at. I'm still in the planning stages. I think I've chosen my engines (Saito Fa-30S silver), but I'm going to have concealment problems with doing the Bristol Hercules cowlings. For scale, the prop shaft must be central. I'm eying up a 9x6 3-blade from Graupner which will just about run and it's scale proportions (well 9.75" really) In the RR Merlin configuration, the engine can be inverted to use up vertical cowling space. I haven't that luxury. I think I'll do about 90 degrees, but sticking way out! I can't find any 4-strokes (4-cycle) smaller than 30 these days so they will be protruding nearly half way I think. I've been trying to get my second hand 2-stroke spitfire up and running - needing re-plumbing, tinkering with, etc. It flew this morning, but not at my hands and conked out in the first loop my local expert put it into. He glided it down nicely (then I reminded him to lower the undercarriage!!) and he landed it softly. I seem not to get too much building time in the week with a job, wife and two daughters coming up to teens soon! It's not going to be as authentically scale as it should be - but so long as it's the right shape in the air, I'll be happy. Talking of which, I see the nacelles on the plan are clustered very near the fuselage. The real aeroplane has them more spread out. Did you move them out? I'm wondering what the deal is there? In the plan, both engines, rather than just the inner ones are vectoring thrust over the tail fins. Also I suppose it helps with yaw if an engine stops. I should probably just follow the plan... but I have a part of me saying "build it as the original" for authenticity... I'll get building proper once the cold sets in I expect. I'm not going to produce half as polished an article as you have there. I will do the balsa and then decide on glass/film/tissue as a strengthening skin, apply a lick of paint, some custom transfers/decals and leave it at that. This is going to be essential if I'm going to get it in the air any time prior to the next century.... After it's up and flying, I may try to spend some time increasing the level of "static display" detail. Regards, Bob
< Message edited by BobGeezer -- 9/10/2007 4:26:48 PM >
_____________________________
Where does all that time go...?
