camdyson
Joined: 7/20/2005 From: Bairnsdale, AUSTRALIA Status: online
O.K., here we go:- Vol 13 No 5 12th Sept 1997 R/C Scale Aircraft (UK) Final weight of electric 6 1/2 lbs.(incl batts)! Wing section adjusted to give a flat bottom, but +1.5 deg incidence maintained Vac formed nacelles, turrets etc were made, and a "drop-down" undercarriage, ie could hand launch, fly, drop U/C, and land! Motors were Graupner Speed 400 7.2 V on 1:1.185 boxes, running on 2 x 8 cell 1700 SCRC SP packs. Assorted 9x5-6 props used. Structure was all lightened - spars, fuse sides, you name it. Covered in tissue and Banana oil/sanding sealer, painted with Humbrols. Flown gear down ROG, and hand launched then gear dropped - flew fine. Moulds were made available from Nexus at the time. I may be able to scan article but too big for RCU - would have to email. Cam
