Steiny
AB, CANADA Status: offline
Gents, Just a quick update, spent about 8 hours over the weekend doing assembly work and almost got it done. Preliminary balance check shows a tail heavy condition which really surprised me, this will be corrected with battery location. Final weight appears to be slightly over 12 lbs dry (YIKES!), this will give a wing loading of about 36 oz/ft2 which is definitely heavier than I wanted. In retrospect to keep the weight down I should not have gone with retracts and the fibreglass finish as I am sure these 2 items alone added several pounds. However what's done is done and I did put in flaps so hopefully that helps the landing speed situation, I am most worried about an engine out situation, with all that weight will it spin??????? At a scale contest all next weekend so the earliest it will fly will be the week of June 30th, I will post pictures and maybe a video from my phone if anyone can tell me how to get audio across from my phone to my PC (*.THM file from a Motorola Razor)? Cheers, Mark
