RE: Engine Recommendation for Yak 73"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> RE: Engine Recommendation for Yak 73"
Page: <<   < prev  1 2 [3]
Login
RE: Engine Recommendation for Yak 73" - 9/27/2007 10:24:32 PM
arobatx
Status: offline
While you are at www.centralhobbies.com check out the Hyde soft mounts. It will be a necessity if you plan to install the 1.60 on the Yak.
Chad
_____________________________
Chad
(in reply to Aussie_Knife_Edge)
       Post #: 51
RE: Engine Recommendation for Yak 73" - 10/27/2007 12:45:54 AM
kochj
Status: offline
This is my engine...
It will be placed in the new 73 yak!!
weights only2lbs 11 oz all up and ready to fly!!
Click to see fullsize image.
Click for fullsize
Winning isn''''t everything, it''''s all there is.
(in reply to chuck4816s)
       Post #: 52
RE: Engine Recommendation for Yak 73" - 10/28/2007 2:38:23 PM
MOTORMAN37
Status: offline
How many are solid mounting YS 1.40 Sport. I am building the Aeroworks .90-1.20 Yak and wondering if a Hyde mount is needed with the YS 1.40.
(in reply to kochj)
       Post #: 53
RE: Engine Recommendation for Yak 73" - 10/28/2007 4:56:51 PM
kochj
Status: offline
quote:
ORIGINAL: MOTORMAN37
I would ask that ?on the ys club..... But I see no need to use a nose ring or any other mounting method other than traditional rail system...
If you use Aluminum mounts (always better because they do not resonate any High frequency waves like a plastic reinforced one does),
you should be just fine..
I wonder if anyone has tried to make a rail syle mount made out of CF?
(in reply to MOTORMAN37)
       Post #: 54
RE: Engine Recommendation for Yak 73" - 10/29/2007 3:49:27 PM
arobatx
Status: offline
I had a YS 1.40 sport hard mounted on mine.... It worked 'fine'. If you are particular about minimizing vibration to save on current draw due to vibration, the hyde mount is a very good investment.
KockJ, is that the new ZDZ 40? I would think that engine would be a perfect match for this plane.
Chad
Chad
(in reply to kochj)
       Post #: 55
RE: Engine Recommendation for Yak 73" - 11/13/2007 6:20:48 AM
kochj
Status: offline
quote:
ORIGINAL: arobatx
Chad
Yes it is!
I will be placing it in a QQ yak GEN II this winter.
Look for a build within the coming months!
Justin K.
(in reply to arobatx)
       Post #: 56
RE: Engine Recommendation for Yak 73" - 12/10/2007 6:54:01 PM
dgrobler
Status: offline
Hi there,
I am planning to start the 73" Yak as my next project and have an OS 120 AX ready to go - I will be flying IMAC with this plane and I fly at sea level. Thought the 120AX would keep the weight down nicely.
Thank you in advanced.
       Post #: 57
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.016RCU1
