RE: SV27 Battery Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: SV27 Battery Thread
Page: <<   < prev  11 12 [13] 14 15 16 17 18 19 20   next >   >>
Login
RE: SV27 Battery Thread - 12/13/2006 12:37:48 PM
Orange Crush
Status: offline
PM'd you a vid link....
_____________________________
Aeromarine Mean Machine/Aquacraft Supervee27/
5700kv Mamba Powered Ruslter
(in reply to Blackjack52)
       Post #: 301
RE: SV27 Battery Thread - 12/13/2006 2:59:27 PM
Blackjack52
Status: offline
IGTCFTSC
I'm going to config for the "Speederson Config" either today or tomorrow, then run it Sun. We're in the 60s then 70s over the weekend. Man, I miss the snow around Christmas. Maybe prop down to the CF45 when I run the packs I heated up yesterday. And get the fire ext out of the truck.
Just to make you happy Speederson.
Splittin' them Hydrogen Atoms
38.4mph 12cell SV
(in reply to Speederson)
       Post #: 302
RE: SV27 Battery Thread - 12/15/2006 2:40:25 AM
gooycheese
Status: offline
Hi Guys,
These are the batteries I got for my brother-inlaws sv27. I hope they work well, since it is winter time is there anything that should be done to these batteries before the spring?
Thank Paul
Click to see fullsize image.
Click for fullsize
Good Luck and Good Boating. :)
       Post #: 303
RE: SV27 Battery Thread - 12/15/2006 10:43:46 PM
djr01974
Status: offline
yeah get a r/c car or truck to cycle them in . lol ... something to do while its cold out .
(in reply to gooycheese)
       Post #: 304
RE: SV27 Battery Thread - 12/16/2006 10:40:05 AM
Funboyfly
Status: offline
quote:
ORIGINAL: gooycheese
Hi Guys,
Thank Paul
At least you should keep these batts balanced and not fully charged.You discharge down to 1 v each cell and you charge 800 mAh for storage then regularly checked (due to the nimh self discharge). That's the protocol I follow with my IB 4200.Doing this will ensure your batteries to be in perfect condition this spring...
       Post #: 305
RE: SV27 Battery Thread - 12/16/2006 3:18:31 PM
jelly bean
Status: offline
i was wondering if this pack would be good for this boat. im probably getting this boat with my christmas money and i dont want to spend too much on batteries.
6C/ELITE1500A/Flat/12AWG Wire/Female Deans
Cars
ofna mbx 9.5 axial .28 spec 1s with jr ST126MG, venom minigiant with all venom mods, greatplanes slinger airplane
(in reply to Funboyfly)
       Post #: 306
RE: SV27 Battery Thread - 12/16/2006 6:40:01 PM
ryan_t888
Status: offline
Aren't those 2/3A cells? I don't believe they would provide enough current to make the SV sing. What ever you decide do not cheap out on batteries.
Ryan
A theory may be so rich in descriptive possibilities that it can be made to fit any data. - P.J.L.
(in reply to jelly bean)
       Post #: 307
RE: SV27 Battery Thread - 12/16/2006 8:48:59 PM
Speederson
Status: offline
Hi Guys,
Thank Paul
How to store batteries
Keep batteries in a cool and dry storage area. Refrigeration is recommended but freezers should be avoided. When refrigerated, the battery should be placed in a plastic bag to protect against condensation
Do not fully charge lithium and nickel-based batteries before storage. Keep them partially charged and apply a full charge before use.
and who thought that putz JB was goofy with the Frig thing.
http://www.batteryuniversity.com/partone-19.htm Batteries 101
http://www.batteryuniversity.com/index.htm
and why do we care about heat.
Avoid overheating, heat is a Nickel Metal Hydride battery's worst enemy.
http://wireless.berkeley.edu/services/battery.shtml#NICKEL%20METAL%20HYDRIDE
Hey Blackjack low amp or high amp?
Long-term maintenance charge of NiMH batteries needs to be by low duty cycle pulses of high current rather than continuous low current in order to preserve battery health.
< Message edited by Speederson -- 12/16/2006 8:57:39 PM >
I Feel The Need The Need For Speed
       Post #: 308
RE: SV27 Battery Thread - 12/16/2006 9:50:08 PM
Blackjack52
Status: offline
Tell me about it Speedo.
9 times out of 10 I read up on something before I do it with the things that cost the most. I don't mind modding a rudder or turn fin out of the blue. Costs nothing to repair. But a set of $100 packs. Dang right I researched refriging the packs for long term storage.
The batt thread is what I follow for some batt mx and where I got the idea: Red is very knowledgeable.
http://www.rcuniverse.com/forum/m_5022782/tm.htm
But you confused me Speedy,
What you talkin' 'bout Willace?
Are you saying to stay away from doing monthly recon on packs by using a c/10 approach to do a re-balance?
So above is recommending doing like a "trickle" charge using 3, 4, or 5A? Just asking. No biggy.
NiCd batts are best when shunted then trickle charged at low Amps prior to eclipse for max charge hold and batt efficiency. But those are NiCd, they have memory issues.
< Message edited by Blackjack52 -- 12/16/2006 9:58:58 PM >
38.4mph 12cell SV
       Post #: 309
RE: SV27 Battery Thread - 12/16/2006 10:01:20 PM
Blackjack52
Status: offline
Low current, I would think, allows the packs to displace the heat evenly, over long term. Allowing a uniform charge with little or no heat (above 100F), @ c/10.
< Message edited by Blackjack52 -- 12/16/2006 10:32:14 PM >
38.4mph 12cell SV
       Post #: 310
RE: SV27 Battery Thread - 12/16/2006 10:39:10 PM
Speederson
Status: offline
"So above is recommending doing like a "trickle" charge using 3, 4, or 5A? Just asking. No biggy."
Ya thats what Im asking to. You like lower amp like I do. But for a high MaH 4500 shouldnt it be at least 3A. Just have to watch so you dont over heat.
Cost money to go to school and Im still paying for my edumacation The way we use these batts I see short life span.
       Post #: 311
RE: SV27 Battery Thread - 12/16/2006 10:43:06 PM
Speederson
Status: offline
More
http://www.batteryuniversity.com/parttwo-31.htm
       Post #: 312
RE: SV27 Battery Thread - 12/16/2006 10:52:16 PM
Speederson
Status: offline
Hey
I know this is for NiCd but I wonder how it applys to NiMH.
"Ultra-high capacity nickel-cadmium batteries tend to heat up more than the standard version on fast-charge. This is partly due to increased internal cell resistance. To moderate the temperature buildup and achieve short charge times, advanced chargers apply a high current at the beginning and then lower the amount to harmonize with the charge acceptance."
http://www.batteryuniversity.com/partone-11.htm
       Post #: 313
