ctonez
WA, USA Status: offline
I have been reading this thread for awhile now and plotting which NiMh packs to get for my SV for the 2007 racing season...but last weekend the club voted to go to Lipos in P-Mono Class, so now I have to take the lipo plunge to remain competitive. The limit is 4s2p 15V maximum. Benmat and the others that have used lipos, do you use 2-2s1p packs? Is your ESC stock? or is there a better configuration of batteries/ESC I should consider? what mAh per pack are you running? Should I start a new thread, or are you guys cool with talking lipos here as well...? Regarding the cost issue: According to the other guys in the club, if you're racing, your NiMh packs will last 1/2 season before they start to degrade and show a drop in performance. The guys using lipos are only recharging once (if that) per day and the batteries last 1-2 seasons. So in the long run, especially if you run alot or are on a racing schedule, it costs a similar anount of money to run lipos. That doesn't take into account charger costs (mine charges all types) or other associated costs, but it still leaves you in the same ballpark after one year of running doesn't it? If I weren't intent on competing, I'd probably stick with NiMh's. Less complexity/hazard/cost.
_____________________________
For best boating results, the Surgeon General suggests you Check Temps Often!
