digitech
Joined: 8/23/2004 From: klimmenlimburg, NETHERLANDS Status: offline
[QUOTE]Originally posted by shockwave Hello Sandor, Nice video of the Raven. Again congratulations on putting everything together and getting her up in the air; I know that this is no easy task. What kind of flight times are you getting? Also have you done any acro experimentation? As far as the 28/10 prop size goes this a target that we hope to achieve. I am always pushing to try to have scale props. on my aircraft. I did have a friend in southern CA. that was successful in turning a 28/10 but this was on the bench and not in the airframe. Again congrats on the Raven flights Take care David [/QUOTE] thanks for the compliment yes sometimes i wish for a simple gas engine well for now we have a small problem we are getting about 7 minutes out of 2 liters of fuel wich is to much , we suspect we have a fuel leak in the turbine or somewhere else , i have send the turbine to wren to be inspected about the scale yes i totaly agree it looks nicer with a true scale prop i have for display shows mounted a 26x12 3blade fuchs i wished we could use that on the bench it runs everything but as soon you go up in revs above 130000 watch the temp it will rise and rise. it is not because of the turbine being inside of the model, actualy now it is very quiet and no difference in temperature we get on the bench about 7500 rpm,s with 150000 on the turbine , believe me you need this speed to fly this big plane. infact we flew her without the spinner and temperature was even higher! that with the spinner not to mention the airspeed i think honnestly as you can see on the video that it "suddenly"goes very fast when in upper rpm,s so i would suggest you run the turbine between 140000 and 150000 to get the best results. but then you will see that the prop speed will stay low and resulting in high temperature like i sayd our first flight resulted in a flame out, it hardly came of the runway not picking up at all at about 20 meters up , the temperature exeeded i think at 800c we had a hard landing downwind resulting in a landing gear fracture , because of the raven it kept strait and did not fall out of the sky this was with a 3 blade 22x11 fuchs our next test we will try to use a 26 x 8 or 26x7 maybe we need to exchange the gearbox i was thinking to get a different setting on that so we can get the maximum out of it with a bigger prop again like you said it is a lot of work but as soon you see her fly you forget immidiatly! and just its a pleasure to listen as for arobatics we toulk it easy on the first run we did some loops . wing overs , cuban,s ,tryed to hover exept it keeps on climbing , so you have to play a lot with the stick we want to try to get the turbine more agressive on the pickup i am shure it can be done again the raven is VERY easy to fly it has no intention to break to one side is very easy to handle even in lower speeds and because of the nice work of wren turbine picks up very fast on lower rpm,s so you can bring her in just like the real thing as you can hear on the video that day was very windy still you can see how easy she come,s in anyway keep us also posted about your testing rember until now there are only 2 ravens on this planet that actualy fly with a turbine it would be cool to see more of them as you can also hear on the video everyone was just talking and talking and loved the smell of the kerosine reg Sandor
< Message edited by Sandor -- Jun 12 2003 10:18AM >
_____________________________
Sandor Kruise Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy,Jet-1A,Composite-ARF. "Home of the Pro-Lynx Gears"
