Silent-AV8R
CA, USA Status: online
quote:
ORIGINAL: murry SPORTSMAN 1- Goldfish. From upright, push to a 45 degree down line. One positive snap. Pull ¾ inside loop to a 45 degree down line. ½ roll. Exit upright. 2- ½ Outside Loop. From upright, 2 of 4 to inverted. Push ½ outside loop. Exit upright. 3- Positive Spin. From upright, 1-½ positive spin. Pull 5/8 inside loop to a 45 degree up line. ½ roll. Exit upright. 4- Vertical Down Line. From upright, push to a vertical down line. ½ roll. Exit upright. 5- Humpty Bump. From upright, pull to a vertical up line. 2 of 8. Push half outside loop. ¾ roll on the vertical down line. Exit upright. 6- Half Cuban Eight. From upright, 2 point roll. Pull 5/8 inside loop to a 45 degree down line. 2 of 4. Exit upright. 7- Hammerhead. From upright, pull to a vertical up line. One roll. Hammerhead to a vertical down line. Exit upright. 8- Inside Loop. From upright, pull inside loop with one full roll at the top. Exit upright. 9- Teardrop. From upright, pull to a 45 degree up line. Pull 5/8 inside loop to a 45 degree down line. Correction: 9 - Pull to 45 upline, Pull 5/8ths inside loop to VERTICAL downline, center 2 of 4 going down, pull to exit positive. quote:
10- Aerobatic Turn. From upright, 180 degree Aerobatic Turn. Exit upright. Jason is this what you wanted murry
_____________________________
Reality is Subjective. At least that's what I think.
