RE: CD ScaleDesigns Sopwith Snipe build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: CD ScaleDesigns Sopwith Snipe build
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: CD ScaleDesigns Sopwith Snipe build - 11/18/2006 11:32:36 AM
TFF
Status: offline
For the scale your doing I think your bamboo would be perfect for the wicker seat material.
Tom
(in reply to abufletcher)
       Post #: 226
RE: CD ScaleDesigns Sopwith Snipe build - 11/18/2006 12:49:06 PM
abufletcher
Status: offline
I've been messing around with a mock-up of the top decking and cowling. My usual practice here is to tape on a sheet of paper then roughly sketch the shape in place. Next I transfer this rough outline to thicker paper and do another rough fitting. Next, I make sure everything is symmetrical (if it's supposed to be). And just keep fitting and editing until I have something that looks pretty good, at which point I'll do a test cutting out of ply. Often this is good enough but sometimes I'll find problems at this stage so have to do a "next draft."
The decking will be of 1/32" ply and we're still working on the forward cowl. Chris hopes to have one molded of polycarbonate very soon. I wouldn't mind trying to experiment with doing theim in aluminum sheet.
These photos are of "second generation" outlines. And obviuosly these are just "basic surface" patterns and the top cowl will need channels for the guns and the rear portion is actually asymmetrical such that you only have "half a cockpit" on the port side and the typical full round cockpit cutout on the starboard side.
I sure wish I could just go stare at one of these cowlings somewhere!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by abufletcher -- 11/18/2006 1:17:51 PM >
(in reply to TFF)
       Post #: 227
RE: CD ScaleDesigns Sopwith Snipe build - 11/18/2006 1:51:31 PM
abufletcher
Status: offline
And as long as I'm shooting mock-ups, I might as well go ahead and post a couple of the cowl. I reworked the angle and shape of the bottom cutout a bit and also added the two inspection holes on the starboard side.
Click for fullsize
Click for fullsize
       Post #: 228
RE: CD ScaleDesigns Sopwith Snipe build - 11/18/2006 3:11:50 PM
TFF
Status: offline
Your approach to the top decking is how you would do it if it were full scale; metal or wood.
Tom
       Post #: 229
RE: CD ScaleDesigns Sopwith Snipe build - 11/19/2006 5:42:16 AM
abufletcher
Status: offline
When attempting a scale model it's always good tto keep going back to the original! Here's the tail skid from Barker's Snipe. I'll try to detail as much of this as possible.
Click for fullsize
(in reply to TFF)
       Post #: 230
RE: CD ScaleDesigns Sopwith Snipe build - 11/19/2006 11:23:07 PM
abufletcher
Status: offline
My oh my! She's starting to look lean and mean! Or maybe fat and sassy!
Click for fullsize
< Message edited by abufletcher -- 11/19/2006 11:27:07 PM >
       Post #: 231
RE: CD ScaleDesigns Sopwith Snipe build - 11/20/2006 1:55:24 PM
BobH
Status: offline
I think it's starting to look pretty cool!.. Are you going to do a dash?
_____________________________
BobH.
       Post #: 232
RE: CD ScaleDesigns Sopwith Snipe build - 11/20/2006 2:02:19 PM
abufletcher
Status: offline
A dash?
(in reply to BobH)
       Post #: 233
RE: CD ScaleDesigns Sopwith Snipe build - 11/20/2006 2:13:02 PM
abufletcher
Status: offline
Here's a further photo study of the panel and cowling layouts. Chris and I have been working quite intensively on the shape of the top cowling. There's not a lot of information on this and the available photos don't show this area well at all. About the best view we have is from a close-up of a plastic kit. Many of the available drawings (including the Nieto drawings in the MAN book) are awful to just plain wrong in this regard. Actually, I wish I had the Replicraft Snipe drawings -- but part of me is afraid I'd go "scale crazy" if I bought them. Best to stick with a scale OUTSIDE here!
Anyone have a photo of this area of McDermott's Snipe?
There's a lot of complicated geometry that has to be just right up front. If you get one thing off (i.e. in a non-scale position) it can end up effecting lots of other lines. We want to make sure we work these things out now.
I hope to be able to get on with the build of the wing center section in the next couple of days.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by abufletcher -- 11/20/2006 3:10:46 PM >
       Post #: 234
RE: CD ScaleDesigns Sopwith Snipe build - 11/20/2006 7:17:33 PM
CliffordH
Status: offline
You have probably seen these images but I thought I would post some of them just in case.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 235
RE: CD ScaleDesigns Sopwith Snipe build - 11/20/2006 7:20:07 PM
CliffordH
Status: offline
Here is a few more, hope you can see what you need to see in one of them.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to CliffordH)
       Post #: 236
RE: CD ScaleDesigns Sopwith Snipe build - 11/20/2006 9:08:23 PM
BobH
Status: offline
Dashboard! lol.. yes.. in the cockpit.. with dials etc. In air terms.. an instrument panel.. hows that? lol
< Message edited by BobH -- 11/20/2006 9:09:00 PM >
BobH.
       Post #: 237
RE: CD ScaleDesigns Sopwith Snipe build - 11/20/2006 11:23:05 PM
