abufletcher
Joined: 2/13/2004 From: Zentsuji, JAPAN Status: offline
quote:
ORIGINAL: vonJaerschky I'm curious what plug you might be using in the Saito. I had a few Saitos, and they all ran really well with the Fox Miracle Plug and 10% nitro fuel, as does the OS. Maybe check for any air leaks around the intake pipe/head joint and the carb/intake pipe joint, too. I hope you get the problems sorted out. I'm not really sure what brand plug it is and I suppose that's part of my problem. It may be whatever plug came with the engine. Actually, the engine once I get the settings right should be great. It starts up quick and strong. I haven't played around much with manual starts but it jumps to life almost as soon as I get the electric starter on it. I've got four other Saitos, so yeah I've had a generally good experience with them. That having been said, the best, most reliable engine I own is a 52 Magnum (actually I've had two other 52 Magnums and one of the others was a total dud). Anyway, I suspect I'll get it sorted out. Besides this is exactly why I mounted it in the "practice plane" instead of the Snipe. By the time I put it in the Snipe, I want to know its operation inside and out. BTW, I wanted to add that I really appreciate all the advice throughout my build. I'm a big believer in the idea that if you ask enough stupid questions you eventually get pretty smart.
< Message edited by abufletcher -- 3/8/2008 4:16:06 PM >
