abufletcher
Joined: 2/13/2004 From: Zentsuji, JAPAN Status: online
I apologize for how slow this is going at the moment. I've promised myself that I'll spend a significant portion of the weekend building (or detailing). This week I've been getting tons of flying in on the Cub so that I can pull the engine. So far I've got over 70 "flights" (counted as full take-off runs from a stand still and a successful landing) in about two weeks. No deadsticks. Two nose-overs on take-off, three on landing (on a rough field with soggy ground). Nothing damaged. Well, almost nothing. I didn't exactly "fly the wings of it" but I did manage to fly the gear off. After about 50 flights the gear finally gave out on landing but some silver soldering had it flying again the next day. I'll probably fly through the weekend and then pull the engine. Today I was trying to get the Saito 56 on the Kyosho Me-109 tuned up and I just couldn't get the idle set. Then I noticed that there didn't seem to be any movement on the trottle arm through the bottom 1/3 of the stick movement. So I checked out the servo and noticed something very odd. On the first third of the stick movement the servo arm actually moved slightly in the OPPOSITE direction! And then moved quickly in the right direction. I figured it was a bad servo until I noticed something odd about my radio: The throttle stick no longer had any "clicks" to it! Just smooth movement. I'm not sure how (or even when) this happened. Luckily I bought a "spare" Airtronics VG6000 last summer (so transfering settings is simple). I gave the new one a try and voila, perfect movement on the servo though the whole range. So what's up with THAT? Has anyone had this happen? I've had this radio for ove 4 years and it's been subjected to a lot of dirt and grim, some oil slime and perhaps even a drop or two of water over the years. What does all this have to do with my Snipe? Very little. Though it's all part of my "grand plan" to have the necessary piloting skills by the time I finish with the Snipe. And of course it's good that I'm dealing with equipment problems now rather than later. For example, during this week I found myself with a dead glow starter, a weak 12V battery, and now a wonky radio. Flying every day has also forced me to develop a good routine to make sure I have everything and that everything's charged and in working order when I get to the field. Anyway, I should have some build updates soon.
< Message edited by abufletcher -- 3/29/2008 12:56:13 PM >
