RE: CD ScaleDesigns Sopwith Snipe build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: CD ScaleDesigns Sopwith Snipe build Page: <<   < prev  57 58 59 60 61 62 63 [64] 65 66   next >   >>
Login
RE: CD ScaleDesigns Sopwith Snipe... - 5/31/2008 7:26:18 PM
abufletcher
Status: online
Now that we've worked out the CG and found the approximate amount of weight needed, it's time to figure out how to attach it to the airframe. Basically, I'm going to be adding it to the rear of the dummy ply panel. To get it as evenly distributed as possible (and as far forward) I decided to try melting the weights down into one thin plate by meliting it into an aluminum pot. This seemed to work well and produced a smooth "pancake" of lead that I can then shape and cut out.
< Message edited by abufletcher -- 5/31/2008 7:36:34 PM >
(in reply to geezeraviation)
       Post #: 1576
RE: CD ScaleDesigns Sopwith Snipe ... - 5/31/2008 7:57:43 PM
abufletcher
Status: online
quote:
ORIGINAL: TFF
I figured out that the actual Spitfire's engine was around 50% of the total weight of the plane, so we are at a disadvantage from the start we have to add weight.
Exactly. As you (and Camdyson) point out the original had a pretty big chunk of metal up front. In fact, we could really think of these WWI aircraft as little more than an engine with a weather vane attached. The whole shape of the aiplane as we know it, is about adding stuff behind the engine to balance it out!
It's all just a game I play with myself. If I could cast a solid lead dummy engine, I'd think that was just the coolest thing ever and would be proud to stick that up front!
< Message edited by abufletcher -- 5/31/2008 7:58:28 PM >
(in reply to TFF)
       Post #: 1577
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 3:51:13 AM
TFF
Status: offline
I would like to add nose weight with this http://www.littlelocos.com/home/littlelocos_003.htm
(in reply to abufletcher)
       Post #: 1578
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 6:09:27 AM
abufletcher
Status: online
Why not go whole hog!
http://ie.youtube.com/watch?v=P_-HhEfH1XQ
(in reply to TFF)
       Post #: 1579
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 7:42:13 AM
abufletcher
Status: online
Here are the roughed out weights for the back of the dummy. They are still much too heavy at almost 800g (combined) but I'll need to be cutting them down in places. I melted down a fairly thick "pancake" of lead (a bit more than 1/4" so that it would be heavy enough when cut down significantly (to about 450-500g). I'll bring them down to below a "fine tuning" weight so that I can add or subtract small weights to fine tune the CG later.
My plan is to bolt these large weights on to the ply plate. I'm still thinking of how to attach the whole thing to the firewall.
Click to see fullsize image.
Click for fullsize
< Message edited by abufletcher -- 6/1/2008 7:49:28 AM >
       Post #: 1580
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 9:56:14 AM
abufletcher
Status: online
I think the only reasonable way to attach this to the firewall is with lock-nuts in the firewall and then bots acting as stand-offs.
Also I'm going to try casting a lead weight that will fit exactly into the mock crankcase plate I made from the bottom of a spray can. I've cut open another can bottom to act as a mould for the lead. If Allan's right about the short arm level thing then moving this weight forward even 3/4" should help lighten the load. I'll also keep the weight as forward as possible by filing lead off the backside of the large weights.
       Post #: 1581
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 10:11:45 AM
CTDavies
Status: offline
Abu,
I'd also think about getting one of those brass spinners as well. You can't place your weight much further forward than that.
_____________________________
"there is no Dark Side of the Moon really,
as a matter of fact it's all dark"
       Post #: 1582
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 10:21:30 AM
abufletcher
Status: online
The information here gives the Saito 56-91 shaft size as 7x1mm that is a metric thread. Tower only seems to carry 5/16" and 1/4" Heavy Hubs.
http://members.aol.com/harryhig/ShaftSizes.htm
Actually, some of the later Snipes did have a small cone-shaped spinner the same size as the propeller hub.
< Message edited by abufletcher -- 6/1/2008 10:24:14 AM >
(in reply to CTDavies)
       Post #: 1583
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 10:29:07 AM
CTDavies
Status: offline
The one I have weighs 136 gramms. It fits on my old FS 61, but I don't know if it has the shaft size you need.
       Post #: 1584
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 10:36:48 AM
abufletcher
Status: online
quote:
ORIGINAL: CTDavies
Is that an OS 61? A bit of googling indicates that the shaft is 5/16x24. How does that compare to 7x1mm? That 136g (4.8oz) might do nicely! Are you offering?
Also I just sent and email off to Harry of Harry's Heavy Hubs inquiring whether he could make a custom conical version. That would be pretty cool!
       Post #: 1585
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 10:48:16 AM
CTDavies
Status: offline
I don't think a metric thread will fit on an imperial sized one at all. If you can do some more research and if you find out that it does fit, I'll send it to you.
       Post #: 1586
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 10:57:41 AM
abufletcher
Status: online
quote:
ORIGINAL: CTDavies
Could a 5/16x 24 be retapped for 7x1mm or is this too close?
       Post #: 1587
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 1:29:08 PM
geezeraviation
Status: offline
Don 5/16 is darn near exactly (canI say that?) 8mm so I dont think it would work. A 7mmx1 requires a 15/64 drill which I have, I'll have to see if I have that size tap in my tool kit at work. What size is the prop hub and how sharp an angle does the spinner have? Do you have a picture of it you can post? I may be able to make one for you if I can find the tap, I have a small lathe, I just turned some brass wheel retainer caps for my N 28c1 in 1/4 scale and I have made my own heavy hubs before. Gotta go, were having a work party at the field today in preraration for out annual Warbird event. I'll ck back when I get home this afternoon. Later, Doc.
       Post #: 1588
RE: CD ScaleDesigns Sopwith Snip... - 6/1/2008 3:51:51 PM
abufletcher
Status: online
Doc, that'd be super-duper cool! The "spinner" that was used on the Snipe (probably post-war) look for all the world like a party
