geezeraviation
Joined: 11/4/2007 From: Houston, TX, USA Status: offline
Don 5/16 is darn near exactly (canI say that?) 8mm so I dont think it would work. A 7mmx1 requires a 15/64 drill which I have, I'll have to see if I have that size tap in my tool kit at work. What size is the prop hub and how sharp an angle does the spinner have? Do you have a picture of it you can post? I may be able to make one for you if I can find the tap, I have a small lathe, I just turned some brass wheel retainer caps for my N 28c1 in 1/4 scale and I have made my own heavy hubs before. Gotta go, were having a work party at the field today in preraration for out annual Warbird event. I'll ck back when I get home this afternoon. Later, Doc.
