RE: CD ScaleDesigns Sopwith Snipe build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: CD ScaleDesigns Sopwith Snipe build Page: <<   < prev  57 58 59 60 61 62 63 64 [65] 66   next >   >>
Login
RE: CD ScaleDesigns Sopwith Snip... - 6/3/2008 2:54:57 AM
abufletcher
Status: offline
The hub area on the APC 13/6 prop is actually a bit smaller than the the prop washer. But then the hub on the APC prop is much smaller than the hub are on the scale (display) prop which would be closer to 1 1/4 inches. But since we're talking about a flying situation here I would think that 7/8" - 1" would be fine.
I hate to impose too much on your here. I'm curious what sort of weight this would come out to be. I'm guessing something like 3 oz.
(in reply to geezeraviation)
       Post #: 1601
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 10:44:30 AM
abufletcher
Status: offline
QUICK QUESTION:
In doing the balancing is the top of the stab the key line? That is to say, should the model be balanced so that the stab is at 0 degrees (even though there is some minimal tail incidence)? Or should the balance be relative to a line running straight through the engine shaft ("thrust line" )?
(in reply to abufletcher)
       Post #: 1602
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 11:29:16 AM
Schnap-Roll
Status: offline
I think your asking fore and aft balance, in which case I go with the thrust-line close to level or slightly nose down. However, don't forget port and starboard balance. Generally the difference between the thrust line and incidence of the stab is only a couple degrees and is negligible. I have never been able to keep the longitudinal and lateral axis straight in my head.
       Post #: 1603
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 11:49:39 AM
Frank Sopwith
Status: offline
quote:
ORIGINAL: Schnap-Roll
slightly nose down.
thats right, a few degrees nose down is needed when balancing !
Frank
_____________________________
BLue Skies Happy Landings
(in reply to Schnap-Roll)
       Post #: 1604
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 12:09:23 PM
abufletcher
Status: offline
quote:
ORIGINAL: Frank Sopwith
You mean the engine shaft is pointing down a few degrees? I guess if the stab is perfectly level that would mean that the engine shaft would be pointing down the amount of the stab incidence (relative to the engine shaft).
(in reply to Frank Sopwith)
       Post #: 1605
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 12:45:03 PM
CTDavies
Status: offline
The thrust line (engine shaft) needs to point down a bit, between 1 and 2 degrees only. It has nothing to do with the stab, it's to ensure that the plane is slightly nose heavy, so to be more on the safe side. You might need to shift around the CoG slightly afterwards anyway.
correction: it's not the engine's thrust line that points down (some planes are built with the engine having downthrust) it's the longitudinal axis of the fuse.
< Message edited by CTDavies -- 6/3/2008 12:48:54 PM >
"there is no Dark Side of the Moon really,
as a matter of fact it's all dark"
       Post #: 1606
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 1:24:47 PM
abufletcher
Status: offline
To continue my never-ending series of "dumb RC questions" How do you guys tell if there's 1-2 degrees of down? Do you just eye-ball it? I'm not sure my eye-ball is calibrated to 1 degree measurements!
I understand measuring down-thrust (and have one of those nifty laser thingies) but this is longitudinal axis of the fuse.
(in reply to CTDavies)
       Post #: 1607
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 3:49:07 PM
BobH
Status: offline
If you have an inclinometer you can tell pretty easy. If your firewall is set at Zero Degrees you can use a protractor set on it and measure the prop shaft to see where it lies. That should give you and idea what the down thrust is.
BobH.
       Post #: 1608
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 4:13:18 PM
abufletcher
Status: offline
quote:
ORIGINAL: BobH
As I said, I know how to measure down-thrust. What I can't figure out is how to check whether the fuse centerline is level or a couple of degrees inclined towards the nose. All this would have to be done with the cowl and prop on in "final flying state" to get the balance right.
Despite the "real (office) work" that still needs to be finished, I finished up the dummy plate and mounting brackets. It looks pretty good but my oh my but that firewall is busy! Looks like a REAL airplane! The weight at this point, nose slightly down (to my eye) is 4.3kg.
(in reply to BobH)
       Post #: 1609
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 4:49:06 PM
TFF
Status: offline
The centerline of the fuse will really end up where the incidences and down thrust equal out, but if it looks like the plane will make a shallow decent across the field, that is what I call nose down. Why dont you get your Legionair up and flying for flight pratice?
       Post #: 1610
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 5:05:41 PM
abufletcher
Status: offline
quote:
ORIGINAL: TFF
Now that I've gotten the new batch of Nelson's Clear needed to "finish the finish" I think I'll do just that. It shouldn't take more than a week or so no more work that assembling an ARF. Between that and the Cub it should get my thumbs in shape and let me know if I'm ready to fly the Snipe. The annoying thing about maiden flights is that you only get one!
(in reply to TFF)
       Post #: 1611
RE: CD ScaleDesigns Sopwith Sni... - 6/3/2008 9:55:48 PM
Schnap-Roll
Status: offline
Your really thinking to much about this. It's really just as simple as the fuselage level or slightly nose down. For the first flight, slightly nose down is a safe bet.
       Post #: 1612
RE: CD ScaleDesigns Sopwith Sni... - 6/4/2008 1:02:26 AM
geezeraviation
Status: offline
Thank you Schnap-roll, were not talking about down thrust we're not talking about stab incidence what we're talking about is does it look slightly nose down. I dont know why this is the way it's supposed to be done, it makes me crazy. Why not move the balance point foreward an 1/8 of an inch and do it level. After all if it's slightly nose down then its not balanced, its a bit nose heavy, isnt it??? Nose heavy is ok, a nose heavy airplane will be particularly un aerobatic but it lives to be readjusted to fly again. A tail heavy airplane can be a very unpleasant experience and often tail heavy airplanes fly only once. Start at about 25% a little nose down and when youve become comfortable enough to spin the model (a few flights down the road) if it just spirals move the CG back 1/8 of an inch at a time and keep working till it enters cleanly and spins about its own axis and that should make all the aerobatics you will want to do with a scale model doable with pizzaz. Oh Don I have the Tap. I have no idea what it will weigh, Ill make one and weigh it, and let you know ASAP. Later Doc.
Hey I went over a hundred posts and no one told me!!
< Message edited by geezeraviation -- 6/4/2008 1:03:29 AM >
       Post #: 1613
RE: CD ScaleDesigns Sopwith Sni... - 6/4/2008 1:20:31 AM
abufletcher
Status: offline
quote:
ORIGINAL: geezeraviation
I've been thinking the same thing. But I suppose this is just "the way it's always been done." And maybe a visual reminder.
Hmmm...I don't think I'll be doing too much spinning with the Snipe at least until bo
