Great Planes Giant Extra 330L KIT build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> Great Planes Giant Extra 330L KIT build Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Great Planes Giant Extra 330L KIT build - 10/12/2006 3:44:31 PM
theo63
Status: offline
well i got this kit from a guy at my feild for half price ans a ton of spare parts and such.
i got started last night and this will be my winter project i can see that,wow thats a lot of wood
i hope some guys here have built this plane as i might need some help
how about some gas engine suggestions,,ill post some pictures tonight
< Message edited by MinnFlyer -- 11/7/2006 3:53:04 PM >
_____________________________
steve
       Post #: 1
RE: giant extra 330l kit build - 10/12/2006 3:52:00 PM
MinnFlyer
Status: offline
Is this the Great Planes Kit?
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to theo63)
       Post #: 2
RE: giant extra 330l kit build - 10/12/2006 3:53:18 PM
mmattockx
Status: offline
It would help to know who the kit manufacturer is, what the actual size is and the expected flying weight. Also, your flying style and expectations (smooth IMAC style or insane 3D)
Mark
Waco Brotherhood #4
       Post #: 3
RE: giant extra 330l kit build - 10/12/2006 4:23:27 PM
theo63
Status: offline
yes sorry about that it is a great planes kit,no insane 3 d as im not ready for that yet
steve
(in reply to mmattockx)
       Post #: 4
RE: giant extra 330l kit build - 10/12/2006 4:30:15 PM
MinnFlyer
Status: offline
I build one of these about 6 years ago. I used a G-62 which flew it, but you really need something more in the 80 - 100 cc range. It's a good build, and a good flier. About the trickiest part is the turtle deck. Take your time! Wet the wood, add some weights and let it sit overnight. That's the one part you really don't want to rush.
Click to see fullsize image.
Click for fullsize
Mike B.
       Post #: 5
RE: giant extra 330l kit build - 10/12/2006 4:44:01 PM
theo63
Status: offline
thanks mike for the picture of the plane in bones,lol i got a picture of plenty of wood at the moment,i started the stab last night and ran into one problem i havent solved to i stopped at that point,has to do with the hinge blocks being glued in,ill post some pictures when i get home from work
steve
(in reply to MinnFlyer)
       Post #: 6
RE: giant extra 330l kit build - 10/12/2006 4:54:14 PM
MinnFlyer
Status: offline
Ok, Steve, I'll keep an eye on this thread
Mike B.
       Post #: 7
RE: giant extra 330l kit build - 10/12/2006 11:13:45 PM
theo63
Status: offline
okay here are some pictures of my first hold up point and was wanting some input before i made a mistake,it has to do with the hinge blocks,i cut the parts out but not real sure how the get glued in,i take it they get glued to the stab trailing edge and against the ribs,do they touch the sheeting at all or do i just center them on the stab trailing edge
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
steve
       Post #: 8
RE: giant extra 330l kit build - 10/13/2006 2:44:41 PM
theo63
Status: offline
hey mike did you make a post here and it didnt show up?
steve
       Post #: 9
RE: giant extra 330l kit build - 10/13/2006 2:47:05 PM
MinnFlyer
Status: offline
Hmmm, yes I did. That's weird.
All I said was - The blocks do not have to touch the sheeting, just the TE and rib
Mike B.
       Post #: 10
RE: giant extra 330l kit build - 10/17/2006 3:22:14 AM
theo63
Status: offline
thanks mike the next day i started on it again it was clear what i was suppose to do i guess i was just working on it too late.
well im back off and getting one half of the stab and elevator done,all the hinge blocks installed,control horn plate in,i have the top of the elevator to sheet yet then i can cut the elevator from the stab
still looking for a gas engine suggestions???
Click for fullsize
Click for fullsize
Click for fullsize
steve
       Post #: 11
RE: giant extra 330l kit build - 10/17/2006 2:37:01 PM
MinnFlyer
Status: offline
Here is a suggestion...
Glue a 3/4" dowl right on top of that control horn plate. Epoxy it to the plate, the rib and the LE.
Sand it to fit the top sheeting, and glue the top sheeting to it as well.
Then, use the type of control horn below.
As for the engine, I would go with at least a 75cc, but something in the 100 range would be better.
Click for fullsize
Mike B.
       Post #: 12
RE: giant extra 330l kit build - 10/17/2006 5:21:51 PM
theo63
Status: offline
i like the suggestion on the control horns,where does one find them and what brand are they?
well im at least going to go with a 80 cc,but what brand of engine,this will be my first gas engine
steve
       Post #: 13
RE: giant extra 330l kit build - 10/17/2006 5:30:18 PM
MinnFlyer
Status: offline
For the control horns, Check DuBro and Sullivan.
As to what engine, Your best bet would be to check with the gurus in the Gas Engine forum.
Mike B.
       Post #: 14
RE: giant extra 330l kit build - 10/19/2006 2:50:19 AM
blikseme300
