spud8939
Joined: 8/27/2002 From: GOLDEN, CO, USA Status: offline
Hi Jim, Actually, the last one I built needed some weight in the tail, that is with the wing swept to make the trailing edge a straight line, and reducing the dihedral to half of that of the original design. One additional thing you should do is to add about 1" to the width of the fin to improve the "fish tailing" tendency of the original design, which is made slightly worse with the wing sweep. You will be hard put to come up with a better flying airplane set up this way. ENJOY!! BTW, I used a K&B .61, so you can use that for weight calculations. Sam
