Homebrewer
CO, USA Status: offline
Page 8 of the OS 1.60 Owners Manual states; "Lubricants may be either castor oil or a suitable synthetic oil (or a blend of both) provided they are always of top quality" Page 10 of the OS 1.60 Owner's Manual states the following procedure to break-in your engine: RUNNING-IN ("Breaking-in" All internal-combustion engines benefit from extra care when they are run for the first few times - known as running-in or breaking-in. This is because the working parts of a new engine take some time to settle down after being subjected to high temperatures and stresses. Therefore, it is vitally important to complete the break-in before allowing the engine to run continuously at high speed and before finalizing carburettor adjustments. However, because O.S. engines are produced with the aid of the finest modern precision machinery and from the best and most suitable materials, only a short and simple running-in procedure is called for and can be carried out with the engine installed in the model. The process is as follows. Install the proper propeller intended for your model. Open the needle-valve 2-2 to turns from the fully closed position and start the engine. Run the engine for two to three minutes with the throttle fully open, but with the needlevalve adjusted for rich, slow "four-cycle"operation. Now close the needle-valve until the engine speeds up to "two-cycle"operation and allow it to run for about 10 seconds, then reopen the needle-valve to bring the engine back to "four-cycle"operation and run it for another 10 seconds. Repeat this procedure until the fuel tank is empty. Refer to IDLING ADJUSTMENT section and fix the idling position where the lowest possible r.p.m., with steady running, is obtained. Re-start and adjust the needle-valve so that the engine just breaks into "two-cycle" from "four-cycle" operation, then make three or four flights, avoiding successive "nose-up" flights. During subsequent flights, the needle-valve can be gradually closed to give more power. However, if the engine shows signs of running too lean, the next flight should be set richer. After a total of ten to fifteen flights, the engine should run continuously, at its optimum needle-valve setting, without loss of power. Coolpower is 17% oil and was for many years recommended by name in OS's owner's manual. However, OS owner's manual now recommend a fuel containing 18% oil. If you wish, 2-3 ounces of castor or synthetic oil wouldn't hurt one bit. I don't think using Coolpower without adding oil would be harmful at all as long as you don't run the engine too lean. Larger engines actually don't need as much oil % in their fuel as smaller engines do.
< Message edited by Homebrewer -- Jan 18 2003 12:50AM >
