RE: Sig Smith Miniplane build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig Smith Miniplane build
Page: <<   < prev  27 28 29 30 31 [32] 33 34 35 36   next >   >>
Login
RE: Sig Smith Miniplane build - 12/9/2012 5:48 AM
Quikturn
Score: 118
Last Login: 5/21/2013
Status: offline
Yup, it's like sweating copper pipe. You need to apply heat to the fittings first to get them up to temp. and then apply the solder and the copper joints will soak it right up.
I wouldn't worry about losing temper. It's not like you're going to get it red hot.
_____________________________
Ultrasport Brotherhood #45
P-40 Brotherhood #35
Hide Signatures
(in reply to KaP2011)
       Post #: 776
RE: Sig Smith Miniplane build - 12/9/2012 12:56 PM
triumphman49
Score: 110
Status: online
KaP2011,
Are you tightly wraping the parts with copper wire before fluxing and soldering?
T-man49
Hide Signatures
       Post #: 777
RE: Sig Smith Miniplane build - 12/9/2012 1:37 PM
KaP2011
Score: 115
Last Login: 5/19/2013
Status: offline
Yes, as tight as I can get it anyway. I've been useing a torch but I'm going to go today and get a new tip for my soldering gun and try again. It's weird, I can solder wire and I can braize with brass rod with no problem but silver soldering eludes me.
KaP2011
AMA #408493
Hide Signatures
(in reply to triumphman49)
       Post #: 778
RE: Sig Smith Miniplane build - 12/9/2012 5:25 PM
senrak
Score: 105
Last Login: 5/5/2013
Status: offline
Heat the joint. When you touch the solder to it, it should melt into the joint immeadiately. If not, pull the solder away and apply more heat. Be liberal with the flux. This is what they should look like
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 779
RE: Sig Smith Miniplane build - 12/9/2012 6:06 PM
Quikturn
Score: 118
Status: offline
Lookin good senrak.
I think using the torch would be best because it's easier to heat a complex object like a wound strut. Heat one side then apply heat to the other side. Apply solder to the opposite side of the heat. The flame shouldn't be what melts the solder. The solder should melt into the heated object.
The Smith miniplane is a good looking kit. You guys are making me want to get one.
Hide Signatures
(in reply to senrak)
       Post #: 780
RE: Sig Smith Miniplane build - 12/9/2012 7:30 PM
KaP2011
Score: 115
Status: offline
Thanks for the advice and encouragement guys, I'll keep trying until I get it right.
KaP2011
AMA #408493
Hide Signatures
(in reply to Quikturn)
       Post #: 781
RE: Sig Smith Miniplane build - 12/9/2012 10:47 PM
Rv7garage
Score: 128
Last Login: 4/26/2013
Status: offline
Correct me if I'm wrong, but copper does not have a temper in the first place? I remember when I had to do my struts & landing gear, I had to get the entire assembly pretty darn hot for it to work well.
#26 Club Saito ***CUB BROTHERHOOD*** #86
My full-scale build: www.rv7garage.blogspot.com
Hide Signatures
       Post #: 782
RE: Sig Smith Miniplane build - 12/9/2012 11:20 PM
KaP2011
Score: 115
Status: offline
Correct, copper does not have a temper. I was worried about the landing gear temper.
KaP2011
AMA #408493
Hide Signatures
(in reply to Rv7garage)
       Post #: 783
RE: Sig Smith Miniplane build - 12/10/2012 12:13 AM
triumphman49
Score: 110
Status: online
Actually, copper does have a "temper" (example as in hard drawn water pipe) and if using a small butane torch, you'll probably see the copper wire turn red . . . but the silver solder will be much stronger than the copper and it gives the solder something to "hold on to" and "fill the joint".
Probably not an experts description, but best I can offer.
T-man49
Hide Signatures
       Post #: 784
RE: Sig Smith Miniplane build - 12/19/2012 5:37 AM
vivwiniata
Score: 100
Status: offline
Will upload some pics of my Smith Miniplane, 74cc Zenoah twin, built in 1996, has over 100 flights on it.
Viv
New Zealand
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 785
RE: Sig Smith Miniplane build - 12/19/2012 6:28 AM
senrak
Score: 105
Status: offline
quote:
ORIGINAL: vivwiniata
Viv
New Zealand
Not a Sig Smith Miniplane, huh.
Hide Signatures
(in reply to vivwiniata)
       Post #: 786
RE: Sig Smith Miniplane build - 12/19/2012 6:52 AM
vivwiniata
Score: 100
Status: offline
Ooops, did not realise this thread was limited to SIG.
Hide Signatures
       Post #: 787
RE: Sig Smith Miniplane build - 12/19/2012 1:29 PM
KaP2011
Score: 115
Status: offline
I don't think it's limited to just Sig' SMP. I think that senrak was joking about the size of you're SMP. A very nice looking SMP I might add.
KaP2011
AMA #408493
Hide Signatures
       Post #: 788
RE: Sig Smith Miniplane build - 12/19/2012 2:15 PM
Rv7garage
Score: 128
Status: offline
Viv- that is one BIG bipe! What does she weigh??
Hide Signatures
       Post #: 789
RE: Sig Smith Miniplane build - 12/19/2012 3:42 PM
Duplicator41
Score: 100
Status: offline
That is one good looking "Mini Plane", nicely done.
Cheers,
So many planes, so little time
Hide Signatures
       Post #: 790
RE: Sig Smith Miniplane build - 12/19/2012 6:46 PM
senrak
Score: 105
Status: offline
You do have a great looking Smith Miniplane. No question about it. Congratulations.
As Rv7 mentioned, it is BIG. This thread is about building a little .40 size model. The "Sig" Smith Miniplane is the subject here. The constructions problems that come up and tecknics used to solve those problems are what is usually discussed. Your pictures represent a fine example of what appears to be a 1/3 scale model, and they just didn't seem to fit here. Do you have some constrution advise about the Sig kit to offer us?
Hide Signatures
       Post #: 791
RE: Sig Smith Miniplane build - 12/20/2012 1:11 PM
RICKSTUBBZ
Score: 139
Last Login: 5/20/2013
Status: offline
Viv
New Zealand
I appreciate your pictures. Plane looks good . I think an occasional side step is cool. Helps keep the thread interesting. After all it is a "Smith Miniplane" . Now, if you were posting pictures and build problems with a CUB I would say you are in the wrong place .
Do you have any video of it in the air posted?
Rick, AMA 115812-WACO Brotherhood #75
To discover something better....You must be willing to try something different
Hide Signatures
       Post #: 792
RE: Sig Smith Miniplane build - 12/20/2012 6:05 PM
rc_wings
Score: 100
Status: offline
Only thing better than a picture of a little smith mini plane.....is a picture of a BIGGER little smith mini plane!!! LOL
Marko
WACO Brother #163
Hide Signatures
(in reply to RICKSTUBBZ)
       Post #: 793
RE: Sig Smith Miniplane build - 12/20/2012 7:15 PM
senrak
Score: 105
Status: offline
Okay. Okay. I guess I am too much of a purest.
Viv. Do you have video?
Hide Signatures
(in reply to rc_wings)
       Post #: 794
RE: Sig Smith Miniplane build - 12/20/2012 7:30 PM
foodstick
Score: 177
Status: offline
Viv, one of the best builders in my club built a similar sized Smith Mini back in the day. It was beautiful as is yours !
What a nice plane to have , enjoy that beauty....I can imagine how well it flies...
Hide Signatures
       Post #: 795
RE: Sig Smith Miniplane build - 1/1/2013 2:48 PM
KaP2011
Score: 115
Status: offline
How precise is too precise? I've spent the last three hours setting up the wings on my SMP. The top wing is 1/4 degree pos. the bottom wing is 1/4 degree neg. I know that both should be 0 degree. Both wings are level and square to the fuselage. Should I keep working at it? I'm a real nit-picker at this kind of stuff, it makes me crazy sometimes.
The last SMP I had was a real pita to fly, I did not build it but I suspect it was not set-up properly. I don't want this one to be the same.
I think I'll just keep at it until it's perfect.
KaP2011
AMA #408493
Hide Signatures
(in reply to foodstick)
       Post #: 796
RE: Sig Smith Miniplane build - 1/1/2013 3:08 PM
OldScaleGuy
Score: 120
Status: offline
Biplanes can be a pain to get set up right initially but you only have to do it once. I would suggest you keep at it, sounds like you are getting very close. Please keep us informed on how it goes for you.
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
       Post #: 797
RE: Sig Smith Miniplane build - 1/1/2013 3:54 PM
senrak
Score: 105
Status: offline
Make them 0-0. If they aren't perfect they will fight one another in the air.
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 798
RE: Sig Smith Miniplane build - 1/1/2013 4:35 PM
KaP2011
Score: 115
Status: offline
Well, the last thing I need is two wings fighting, I'm sure I'll have my hands full anyway.
I decided to back off from it for a little while. Re-arrange my workshop.
KaP2011
AMA #408493
Hide Signatures
       Post #: 799
RE: Sig Smith Miniplane build - 1/1/2013 4:45 PM
RICKSTUBBZ
Score: 139
Status: offline
quote:
ORIGINAL: KaP2011
Hey there KaP,
There is no such thing as too precise .
All kidding aside I would shoot for getting the wings right were you want them. 0 and 0. But it will fly with them out 1/4°. After all how accurate is your measuring device ? I would suggest, since you did not mention it, that you pay attention to the stab incidence as well. Since you can control some of that relationship while you are messing with the wings. A little positive in the stab (up in front) in comparison to the wings is a good thing on this plane.
Good Luck with it.
Hide Signatures
       Post #: 800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
