inverted with a blade cp?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> inverted with a blade cp?
Page: [1] 2 3 4 5   next >   >>
Login
inverted with a blade cp? - 10/16/2006 8:56:50 PM
chopperdudes
Status: offline
hello everyone,
i was doing loops and crashed 2 out of 5. and i decided, wat the heck, and want to learn to hover inverted. i don't have a sim or anything, only 14yo. the blade cp was my first heli. can do everything with it upright, got a futaba 7c, lipo and bh upgrade...
ok, so i decided, hmmmmm, i dont have the $$$$ to try it out in real knowing that i would DEFINITELY crash, so... i made an X with zip ties across the skids, and hung it to the ceiling. i first initialed the gyro while upright, and then hung it upside down. i spooled it up on normal and then flipped it up to idle up 1. it was doing ok... then, as i add negative pitch, the heli starts to jump up and down, more negative, faster jumps, i didnt go any futher than that and took it to thorttle hold.
so... why is it jumping up and down as i add negative? (not sure if i'm in negative, or still in the positive range, if that's the case, then reducing positive) how might i learn to fly inverted? i will be getting a bigger bird sometimes after the winter (if no good deal shows up in my lhs 2nd handed)(probably a trex). should i learn to go inverted on that bird? i do find that rudder is reversed and can really mess me up. dont have a hh on my blade. anyone here learnt to go inverted with a blade and not a better heli?
ANY suggestion is appreciated.
_____________________________
i wont buy anymore helis, i wont buy any more helis, i wont, wow! is that a ? i won't buy any more starting tomorrow.
       Post #: 1
RE: inverted with a blade cp? - 10/16/2006 10:01:22 PM
X3n0
Status: offline
what blades are you using. flat bottom or symmetrical
(in reply to chopperdudes)
       Post #: 2
RE: inverted with a blade cp? - 10/16/2006 10:03:40 PM
chopperdudes
Status: offline
esky wood symmetricals, cheaper than eflights...
< Message edited by chopperdudes -- 10/16/2006 11:01:22 PM >
(in reply to X3n0)
       Post #: 3
RE: inverted with a blade cp? - 10/16/2006 10:21:49 PM
sox101
Status: offline
The best, and only thatt i know of, way to learn flying inverted is with a simulator.
       Post #: 4
RE: inverted with a blade cp? - 10/16/2006 11:07:41 PM
lwatson
Status: offline
If you have jumping, you have a sticky collective. Not to say, I have ever flown upside down. But trust your gut, if you see weird behavior like that, then something is wrong. Remember with negative pitch the collective slides into an entirely different range than it is used to.
(in reply to sox101)
       Post #: 5
RE: inverted with a blade cp? - 10/16/2006 11:35:49 PM
chopperdudes
Status: offline
i think i have a theory to my own problem, tell me how likely this is...
since i made an X with zip ties on the skids, it'll stretch like a rubber band because the cf rods on the skids are not stiff. and while i might think i'm adding in negative pitch, i'm actually on the way of reducing positive pitch, it came to a point where the positive pitch has the power to pull it down but not have the power to correct it's 'rubber band' bounced up, and as soon as it bounces up, the 'rubber band' releases and it drops back down.
it is confusing, but try tying two strings across the skids to make an X, then gently pull on the middle of the X, you'll see what i mean. i doubt i have a sticky collective. i lube all parts and running bh with 3bb blade grips.
(in reply to lwatson)
       Post #: 6
RE: inverted with a blade cp? - 10/16/2006 11:54:52 PM
Chriscru
Status: offline
quote:
ORIGINAL: chopperdudes
Chopperdudes,
What part# are you using? If those work on the CP they should work with the CPP I dont want to spend another $15 for main blades..
Chris
"If You Arent Running Gas What Are You Doing Here?"
       Post #: 7
RE: inverted with a blade cp? - 10/16/2006 11:58:29 PM
chopperdudes
Status: offline
i would be alowed to order online shortly, if you can order online, get a pair of those $8.00 sym blades from helidirect.
(in reply to Chriscru)
       Post #: 8
RE: inverted with a blade cp? - 10/16/2006 11:59:10 PM
jent
Status: offline
it is possible you are having a ruber band effect.....try just holding on to it, m,ake sure you got it good and the blades are clear and spin it up....add some negative pitch. See if the presure feels smooth or jerky. If it is smooth then I bet you are experincing a rubber band effect. Otherwise something is wrong....start diagnosis.
cheers,
jent
       Post #: 9
RE: inverted with a blade cp? - 10/17/2006 12:08:32 AM
chopperdudes
Status: offline
ya, forgot to mention, i did do that and the pressure is even. i guess then i'd have to wait for a simulator. btw, i saw g3 in china for 350 bux chinese. it doesnt include a tx, but includes a usb cable that allows you to plug the blade tx into your computer. i might get my grandparents to get it and bring it over, since they are immigrating to canada. but that will likely be in the spring. i know teh concept of inverted really good, and can do it in g3 demo that i downloaded, but i uses the keyboard. so it's just not the same.
(in reply to jent)
       Post #: 10
RE: inverted with a blade cp? - 10/17/2006 3:16:33 AM
Dynamic
Status: offline
Is it a dumb question to ask if your in idle up mode?
T-Rex SE 65MG DS3400 G500T
BCPP DX7 THUNDER POWER
       Post #: 11
RE: inverted with a blade cp? - 10/17/2006 3:33:13 AM
TheVirus
Status: offline
http://www.helidirect.com/product_info.php?products_id=779 Those?
(in reply to Dynamic)
       Post #: 12
RE: inverted with a blade cp? - 10/17/2006 8:37:42 PM
chopperdudes
Status: offline
yes, i'm in idle up and yes, those are the blades.
(in reply to TheVirus)
       Post #: 13
RE: inverted with a blade cp? - 10/18/2006 3:59:18 AM
olds455
Status: offline
Where is your upright hover in Idle up? 3/4 stick? 1/2 stick? I ask because in idle up at middle stick should be zero pitch. Upright hover should be above that and inverted should be below mid stick. Ive flown my cp inverted, flips, rolls, loops, And even some invert hover. Ive found that the pitch can be manipulated buy changing the links between the blade grips and the mixer. If you have a pitch gauge, check it there. I get +10 to -10 Im in the middle of a rebuild from a loss of control fron inverted hover. Oops the pice is this spring(winter)
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 14
RE: inverted with a blade cp? - 10/19/2006 9:56:18 PM
chopperdudes
Status: offline
the pitch i'm not too worried about, i hover between midstick and 3/4. i have a 7c to do all the programming. so by what you mean... FLYING in inverted is easier than hovering? i've done loops... but that's it. i also found out that the motor will stall very badly and the headspeed will decay if i give a jab of collective. what setup do you use on yours? gyro? bl motor? or all stock? i got a bh upgrade and a lipo.
(in reply to olds455)
       Post #: 15
RE: inverted with a blade cp? - 10/19/2006 10:12:44 PM
