mtt3107
Joined: 8/31/2006 From: West Chester, OH, USA Status: offline
The control throws are first calculated, and then confirmed during flight test and certification, or modified as required. Same goes for the CG range, it is firts calculated, and then in test flight, the safe max. forwrd and max. aft CG position is determined during flight testing. Every airplane which comes off the assembly line is weighed and it's basic empty operating weight and CG are established and recorded. Basic Empty Operating Weight is the aircraft, with all required gear for operation onboard, but no fuel, payload or crew. This document is part of the airplane, and has to be onboard at all times. It is sthe starting point for the weight&balance report, which has to be calculated before each flight, and in which the amount of cargo and it's location, quantity of fuel, and quantity of passengers aboard is taken into account. Once it is completed and the CG location is established, the flight creew receives it, and takes it into account for the setting of the elevator trim on takeoff. And the basic empty operating weight and CG has to be established again every time additional gear is installed, or major repairs have been performed, even if the airplane receives a new paint job.
