artechdesign
Joined: 6/10/2006 From: sydneynsw, AUSTRALIA Status: offline
gear doors are there to help the flow of water over the hull they do flood but as long as the water is flowing over the hull and not hitting the bulkhead there is no reason for the nose of the plane to dip down use rubber boots that are made for RC boats put S/S cable through boot and then grease with marine grease at this stage the cable and the boot is not fixed to the plane at all fill the boot up with white roofing silicone and let dry over night drill to holes just big anoth to fit cable through, add push pull system to end of cables and attach servo slid rubber boots up to bulkhead and silocone in place let dry overnight i used robart 530 tri gear that is set up for this plane install nose wheel shape and make hatch that runs from top of opening to landing gear when it is fully down glass this hatch and paint in white epoxy, when dry fix into place with white silicone shape and make gear doors first in one peace and then split them down the middle allow a slight gap in middle use great planes hinges and cut slot 4 off in edge of hull running long ways before glassing doors place hinges on gear doors and mark location cut into gear doors from face and tack hinges with CA then glass over doors and hinges to give them strength, once doors are glassed paint in white epoxy slide hinges into slots, turn plane over and epoxy hinges to plane from inside i will get photos of doors if wish also i have a CD with the seawind landing on water and gear doors etc going down and plane taxing up onto land if i can download film i will regards Trevor.
