Pull-Pull setup
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Beechcraft C-45
Seller:  lennyh
Details:   $9,000.00   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> JTEC / RADIOWAVE Support >> Pull-Pull setup
Page: [1]
Login
Pull-Pull setup - 10/17/2006 5:58:05 PM
gdavisjr
Status: offline
Al/Kevin,
Question... what do you use to make your rudder servo arms out of? Where do you get the material? Do you sell arms by chance? I definitely like your pull-pull setup--easy and simple, yet very functional.
Gerry
PS--Where do you guys normally exit the fuselage for your pull-pull wires on the 40% 330L?
       Post #: 1
RE: Pull-Pull setup - 10/17/2006 9:43:42 PM
jtec radiowave kid
Status: offline
Gerry,
I am not positive what rudder servo arms you are talking about because we have a couple different setups in our personal planes. I have a feeling you are probably refering to the phenolic ones. They are actually made by Comp Arf, I stole some from Jason Shulman a couple of years ago and have been reusing them. They work really well with the Futaba 9152's because most companies don't have a large arm for that spline. I bet you can probably go on there site and buy them.
As for the exit of the pull pull, if you feel the back of the fuselage you will find two cutouts for rudder servos on each side. We generally make the exit about 1/2 inch to 3/4 lower then those servo cutouts and in between the two of them on each side. We try to keep it pretty basic when setting them up.
Click to see fullsize image.
Click for fullsize
_____________________________
www.jtecrc.com
www.composite-creations.com
(in reply to gdavisjr)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.219RCU1
