RE: aeroace mods    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Indoor & Micro RC Flight >> RE: aeroace mods
Page: <<   < prev  1 2 [3]
Login
RE: aeroace mods - 11/7/2007 3:04 AM
dragonclass
Score: 100
Last Login: 8/28/2009
Status: offline
Here are my two cut jets. They fly much better than stock, especially after the throttle mod so you can concentrate on flying.
Click to see fullsize image.
Click for fullsize
< Message edited by dragonclass -- 11/7/2007 3:05 AM >
_____________________________
EN1 Beaty
Hide Signatures
(in reply to micro_builder)
       Post #: 51
RE: aeroace mods - 11/17/2007 9:04 AM
Flyin C
Score: 100
Last Login: 6/10/2009
Status: offline
This is my stock AA, the Canard
Thread here-
http://www.rcuniverse.com/forum/m_6605702/tm.htm
This is all from the original plane except the vertical stab. Its flys very well and Looks GREAT!
My own design
Click for fullsize
Click for fullsize
< Message edited by Flyin C -- 11/17/2007 9:07 AM >
Hide Signatures
(in reply to dragonclass)
       Post #: 52
RE: aeroace mods - 12/30/2007 4:27 AM
weeweeboi
Score: 100
Last Login: 10/14/2008
Status: offline
I think the best mod for the aero ace jet it to simply put a dime under the nose. The climb rate is amazing. I get up to about 200ft in about 45seconds.
You invest so much money in a r/c heli. Why not just buy the real one.
Hide Signatures
(in reply to Flyin C)
       Post #: 53
RE: aeroace mods - 1/12/2008 2:00 AM
yoyoboy
Score: 100
Last Login: 8/17/2011
Status: offline
i have a quick question. has anyone made a mod to attach trail a banner off the back of the plane for the bipe.
Hide Signatures
(in reply to i live for 3D)
       Post #: 54
RE: aeroace mods - 1/12/2008 2:52 AM
FERNDALE AIR FORCE
Score: 115
Last Login: 3/2/2012
Status: offline
I have flown with ribbons on my planes, only silk worked well.
Tim
"...never stop flying the airplane..."
Hide Signatures
(in reply to yoyoboy)
       Post #: 55
RE: aeroace mods - 1/18/2008 5:16 AM
weeweeboi
Score: 100
Status: offline
i attached orange tape stuff like a inch wide and very light, the plane flies fine, i have the jet
Hide Signatures
(in reply to FERNDALE AIR FORCE)
       Post #: 56
RE: aeroace mods - 2/16/2008 3:54 AM
Teenage Pilot 14
Score: 100
Last Login: 4/24/2011
Status: offline
Not sure if anyone's tried this, but I use speed and low drag to combat wind. It's real easy to do; just cut 1 1/4 inches off your wingtips. This only benefits the mono as far as I know. Careful, though; you'll need almost full throttle just to stay up.
P.S. My personal opinion is that you can remove about half of any Air Hogs plane's wingspan and it'll still fly. I cut 6 inches off my Rolling Fury and it flies just fine.
If it ain''t broke fix it til'' it is!
Hide Signatures
(in reply to weeweeboi)
       Post #: 57
RE: aeroace mods - 3/1/2008 4:03 AM
micro_builder
Score: 105
Last Login: 8/10/2012
Status: offline
for anyone needing spare parts -
PicooZ/Havoc main and tail motors
X-Twin/Aero Ace motors and props
PalmZ/Nano Hawk motor/gear/prop assembly
they'll soon be available:
http://www.rcgroups.com/forums/showthread.php?t=825953
Michaels shop:
http://www.indoorflyer.co.uk/
i've ordered from him on more than a few occasions and shipping is always quite fast, his prices are good too.
nick
Hide Signatures
(in reply to Teenage Pilot 14)
       Post #: 58
RE: aeroace mods - 10/26/2008 11:25 PM
BGR
Score: 100
Last Login: 12/2/2012
Status: offline
Hello all I have a question about the AA charger in the TX.
There are a pair of 4.7k resistors (R41,R42) in parallel on the output of the charging circuit. I would think that if one of these were removed that the charging current would drop from 3C to about 1.5C which would hopefully increase the life of the Lipo.
Has anyone done this?
Does it work ok?
If it does work would a 10k Variable Resistor trimmed to allow only a 1C charge work?
Oh I just noticed that they are 4.7 ohms not 4.7k.
< Message edited by BGR -- 10/27/2008 8:05 AM >
Hide Signatures
       Post #: 59
RE: aeroace mods - 11/1/2008 5:11 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
BGR, the lipo only achieves nominal charge (3.7v) from my testing. My testing way back when idicated that I was getting a 2s/1c or 7.4v 100mah charge. I did just open up a new tx and found new stuff inside. You'll usually get a quicker response on the aeroace thread.
Tim
Hide Signatures
(in reply to BGR)
       Post #: 60
RE: aeroace mods - 4/2/2009 5:42 AM
trroadster
Score: 100
Last Login: 10/9/2012
Status: offline
Hello again boys and girls. The depron bandit has been squirreled away in his workshop and it's time for show and tell...
The C-119 flys very scale like and resonates quite loudly. Kinda like the original. The super connie took some time to trim but now is an excellent flyer. The CF-100 is untried (maiden tomorrow). The 737 is a remake of one that flew ok on AA bipe guts until it had a wingtip chewed off by a larger plane. I resurrected it to try JetScream fans...WOW...up in the rafters at the lowest throttle setting. (I,m thinking of calling it "Dogpatch Air" for obvious reasons.
The A-26 was a slingshot glider that I modded with Minium motor gearboxes and the brick from an MCX heli (2x esc) Maiden tomorrow.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 61
RE: aeroace mods - 9/2/2009 4:14 AM
Aircraftfreak15
Score: 115
Last Login: 2/25/2013
Status: offline
trrod can you send me the plans for the f-15 plz
every plane has an experation date its just a mater of when some last for 1 flight others thousands
Hide Signatures
(in reply to trroadster)
       Post #: 62
RE: aeroace mods - 1/1/2010 1:52 AM
Sopwith ACE
Score: 100
Last Login: 7/18/2011
Status: offline
Whats the best way do an acuator
Hide Signatures
(in reply to Aircraftfreak15)
       Post #: 63
RE: aeroace mods - 1/1/2010 4:58 AM
trroadster
Score: 100
Status: offline
Sorry man, don't get back here very often as it has gone quiet. The plans are in the AA toolbox. There is a link on page one of this thread
quote:
ORIGINAL: Aircraftfreak15
Hide Signatures
       Post #: 64
RE: aeroace mods - 1/1/2010 6:03 AM
FERNDALE AIR FORCE
Score: 115
Status: offline
You might look for Microflyer as well.
Fern
Hide Signatures
       Post #: 65
RE: aeroace mods - 1/21/2010 1:37 AM
Aircraftfreak15
Score: 115
Status: offline
Thank you the jet cat is one of my favorit desighns might inlarge it to a 18 inch span and try to use parke zone gear in it. iam going to make and aa one frist.
Hide Signatures
       Post #: 66
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
