alan0899
Joined: 4/17/2006 From: Cundletown, NSW, AUSTRALIA Status: online
G'day Drew, The voltage has to stay above about 3.2volts, with your battery under load, before you may have a problem, if it now takes 5 flights to drop below 5 volts, then don't fly more than 5 flights on a charge, because the batteries are flat at 5.5 volts for a 6 volt pack, ie, 5 cells at 1.1volts per cell, means it is flat at 5.5 volts, under load. It matters not whether it is a Spektrum radio or any other, if you fly with flat batteries, you is gunna crash!!!!! In other words, if it will fly ok with the radio you use now, it will still fly ok with the Spektrum, just don't fly after your batteries get below 5.5volts, UNDER LOAD.
_____________________________
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee, Allan.
