AWorrest
NE, USA Status: offline
quote:
ORIGINAL: We3R/C Hello, I Am a new Dx-7 owner and have a question. I just recently got an Ar6100,and would like to use it in Two planes(Not at the same time, duh!) What I need to know is can I bind It in One plane, with one set of settings, then swap it to the other and Bind again? Or Is the Bind only good for One Plane(Model Match?) I ask this because I am To cheap to buy another Ar 6100 for these foamys! Thanks,Mike Mike, The easiest way is to set up a model on your transmitter for each of your planes. While you will have to rebind each time you swap the receiver from one plane to the next, at least the trims, travel settings, rotational directions, etc. would be saved for each plane. Keep in mind that by swapping the receiver between two planes you could defeat the safety offered by Model Match. If you forget to switch the model number on the transmitter and forget to rebind the receiver after putting it in the new plane, the settings from the previous plane will be in effect! Allan
< Message edited by AWorrest -- 3/20/2008 8:11:00 AM >
