Rfabbre
CA, USA Status: offline
quote:
ORIGINAL: BaldEagel quote:
ORIGINAL: Rfabbre Question for the DX7 experts. Is there any way to do expo on the throttle? Thanx in advance, Rich As far as I can see there is no way to put true expo on the throttle, however you can put a hump in the throttle curve by mixing THR too THR on a mix setting and introducing an offset, having said all that the easiest way to put expo on the throttle is too arrange the throttle servo horn to be pointing straight down the push rod on throttle cut, and have the linkages set up to give full servo movement for WOT, this gives you slow throttle opening from idle and a much faster opening as the throttle gets up towards full, I use this method on my petrol engines as its only the first third of the throttle opening on a Walboro carb that has any effect in real terms. Mike Thanx Mike. I was afraid of that. I do already have my servo alignment pointing straight down the pushrod at idle and that does help a lot. However, it sure makes getting the idle speed adjustment just right as trim has no effect. Rich
