TexasSkyPilot
Score: 430 Joined: 2/2/2004 Last Login: 3/21/2010 From: San Antonio, TX, USA Status: offline
quote:
ORIGINAL: BaldEagel quote:
ORIGINAL: dick Hanson quote:
ORIGINAL: BaldEagel Why do we put up with a manufacturer that does not fix the problem of Brown out, but just makes the Rx turn back on quicker, it is unacceptable in my opionion for Spektrum not to have fixed this very real problem so that the Brown out does not happen so close too the maximum voltage of a four cell pack. My DX7 Spektrum will not be flown in any of my airframes, a sad fact, but I just don't trust this manufacturer anymore. Mike You can't please everyone - BTW- your evaluation of the low voltage cutoff is incorrect. Your right Dick you can't please everyone, but the fix is just that, it was not a cure for the problem, just a quick fix that has not been taken to the extent of a permenant cure. Why is my evaluation of the low voltage cutoff incorrect? Oh and by the way I am also a genius, having never had a hit on my Spektrum, use only A123 batteries and flew other systems to evaluate against the Spektrum, my point is the manufacturer supplied 4 cell Nimh for the RX and servos and its been proved to be lacking and can be the cause of an inherant problem, this can not be justified even if I typed it in capitals. Mike Nope, that is INCORRECTOMUNDO...... The Manufacturer supplied an 1100 mAh 4-cell pack that comes with standard servos, and that setup is fine as froggie hair and will do perfectly. It has been proven to be no problem at all. I and many of my friends use that setup as well. Should you start adding high-draw components and fail to add any of the basics in supporting gear, you have NOBODY to blame but yourself when you crash. Do you know that my Thunder Power charger shuts itself off when the voltage supplying it drops to 10.5 volts. I wonder why that is? Who cares? Let's blame the manufacturer. I don't care WHY some kind of safety is built into a piece of technology, I just want to BLAME somebody when I fail to use it right. Speed controllers are set up with a shutoff that disconnects the LiPos when they drop to a certain voltage. I wonder why that is? Let's BLAME THE MANUFACTURER!!! I don't care that the safety is designed to save my expensive batteries, I wanna BLAME somebody!!!! Now let's look at the Spektrums again. These are computerized RXs, so their effective voltage had to be set to blink at SOME voltage. If these were run at a base Voltage of 48 Volts on batteries that are charged to usually around 53 volts, and your batteries were wearing down, where would YOU set the cutoff? It's computerized, there is a cutoff, get over that part. Where would YOU put it??? Let's see, we've run it from 53 all the way down to 35, that's more than HALF of the battery's voltage!! (51.42% to be exact...) I'd say that, using a chart that shows the normal usable voltage of a niCad or a NiMh battery that we've pretty much taken ALL of the usable voltage. Beyond this it's going to just dump... so you're gonna crash anyway. So, WHERE exactly do you expect it to come from? As I already pointed out, they have provided a battery that is quite sufficient for the setup they come with. Provided that you are actually smart enough to use a Voltmeter and charge your battery when it needs it, and the Manufacturer has to extend the trust at some point that you are at least THAT capable. This leaves the only logical assumption. It has to come from YOU. YOU have to have enoughs brains to know that more draw requires more battery. YOU have been told about the voltage cutoff, so YOU are forewarned AND forearmed. YOU want to use the system for MORE than it comes standard with, so YOU need to increase the voltage, increase the battery size, COMPENSATE for YOUR CHANGES to the stock setup. There IS NO CURE REQUIRED. If you put a bigger engine on the nose, you beef up the nose. If you're gonna fly it hard, you wrap the wing joint in fiberglass tape. You know the engine can pull the nose off. You know the wing can fold. And here you KNOW the voltage where it cuts off. Quitcher B[]TCHIN and use your head. BEEF IT UP. USE YOUR KNOWLEDGE. Many tens of thousands of us are using these without incident. And to be sure, we are all genuises. Or maybe we realize that a tiny fraction of one percent of us having problems statistically means it's almost PERFECT. Because prior to these radios coming out, WE ALL lost planes to the hundreds of diffrent kinds of hits out there.....hits these radios prevent. Some of us just can't seem to enjoy anything, almost like they need to B[]TCH about SOMETHING. Not this boy. I love my DX7 Spektrum radio. More piece of mind, and one less potential reason for bringing home the dreaded Bag-O-Balsa!! And so do ALL of my flying buddies here in San Antonio, TX!! Jimbo
_____________________________
~ J ~<br>It is ALWAYS harder to do the right thing. And it is ALWAYS worth it, no matter what. <br>Jim, AMA 543443 WACO Brotherhood #86, Clip-Wing Coupe Brotherhood #1
Hide Signatures
