RE: WHAT'S WRONG WITH NITROPLANES.COM?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: WHAT'S WRONG WITH NITROPLANES.COM?
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 10/30/2006 8:25:07 PM
RC_DESI
Status: offline
Another recommendation on the Yak is to imrpove the beveling of the control surfaces at the hinge line.
On my Elevator/Rudder I had to leave a noticable gap to get the 30-40 degrees throws (needed for 3D etc). Same for ailerons.
Also a fiberglass cowl/wheel pants would be a nice addition. SAE (instaed of metric) hardware would also be nice.
(in reply to RC_DESI)
       Post #: 51
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 10/31/2006 3:28:04 AM
GotSky
Status: online
THIS POST IS NOT RELATED TO ANY ISSUE WITH NITROPLANES OR THEIR PRODUCT BUT RATHER TO A QUESTIONS POSED TO ME FURTHER UP IN THIS THREAD. BUT IT MAY ALSO HELP ANYONE BUILDING THE YAK 54-140 THAT IS ALSO SOLD BY NITROPLANES. http://www.nitroplanes.com/cmpyak54arf1.html
OPJOSE
Just take your time with the YAK 54-140. Remember that any extra glue that you use in this thing will turn into weight you have to add to the nose later. I am using a Moki 1.80cc 2-stroke, 2x1400mah packs, servo isolator, On board glow driver with 2 cell driver battery plus all high torque servos. I changed all the hardware out for Dubro 60 size horns, I also used ROBART hinges all the way around. Make sure you pit the fire wall for better epoxy bond and I put a 1/4 wide x 4 inch long piece of carbon fiber on the rear horizontal stab to help strengthen the rudder mounting area . I did not use the wing springs but instead use bigger allen head bolts and blind nuts I think they were 6/32 to hold the wing on. The anti Roll pins will not line up where marked on the fuse and wing just be aware of this before you start to drill. Take some 1000 grit paper to the wing tube as it is almost to tight to fit in the wing. Get rid of the stock tank and use a Hayes or similar brand. I went with a 12oz... The plane is on the heavy side and will land faster than most. It will also tip stall easier due to the high wing loading. Don't bother putting on the wheel fairings as they will just break off right away. Also the stock foam wheels are not great, I say use them till they fall apart. The canopy is very brittle and will crack easily so watch out for that when mounting. Other than that have fun with it,...
P.S. Be careful with the elevator throw as this plane will snap with to much input
< Message edited by GotSky -- 11/8/2006 9:04:13 AM >
(in reply to opjose)
       Post #: 52
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 10/31/2006 3:38:57 AM
GotSky
Status: online
arvind-rao
Not to jump in on your post to Nitroplanes but if you are referring to the New YAK 52 that they just released -- http://www.nitroplanes.com/yak523d5056n.html -- The cowl is fiberglass as well as the wheel pants. Also the control surfaces on mine lined up pretty dang close and yes it will 3D very easily, but I do suggest using ROBARTS or similar hinges and not the CA hinge that come with the kit. Also a bit of BINDER Tape on the hing gap is suggested. I also think that SAE is not going to happen as most everyone in the world is metric the USA is pretty much the last hold out on that one. Just my 2cents but thought it may help... Happy flying
       Post #: 53
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 10/31/2006 5:24:32 AM
tracyireland
Status: offline
I know that you cannot please everyone and those who buy a value priced plane should not expect it to be perfect. Furthermore, with a value product you should expect to require some upgrades out of the box. I bought my P-51 Nitroplane with this clear in my mind. I planned to upgrade hardware and I knew the manual was far from perfect thanks to this forum. I overcame the manual problem by downloading the very similar Hangar 9 manual (which is excellent). I am not here to bash Nitroplanes or vent because there is a place for their product. I will however share my expereince so others know what to expect:
1. The manual is very bad. Overcome this by downloading the Hanger 9 manual.
2. Don't expect any support. Nitroplanes does not return phone calls or emails. (At least not mine) This must be one way they keep their prices so low.
3. You get what you pay for:
- The covering is low grade and poorly applied.
- A lot of things don't fit right so expect to do a lot of sanding and cutting.
- You might not get all of the hardware (I didn't). This is OK because you will probably want to upgrade anyway.
- My canopy was scratched so bad from vibration in shipping that the top is translucent not clear Hangar 9 sells a nice replacement that seems to fit.
- The retract wells do not cover the entire retract. This is OK if you don't mind a bunch of dirt in your wing. I thermoformed a patch for this.
- You will definately want to replace the engine mounts and reinforce the firewall for a big 4 stroke.
- The fuel tank mounting leaves a lot to be desired. Expect to buy some balsa to build this up to keep the tank from moving around.
4. Be sure to measure and re-measure everything. The lines on my firewall were off by .3 inches. Mounting my engine referenced to the lines would have been disaster.
5. Check the structural integrity of the fuselage.
- My fuselage had broken or unglued joints.
- This can be fixed with a syringe feeding 30 minute epoxy through a long tube and inspecting every joint with a small mirror and penlight.
In my opinion, buying a Nitroplane kit is a tradeoff in time versus money. I have put together similar kits in about 6 hours and maybe 1 trip to the hobby shop. The Nitroplane took 18 hours, 4 trips and about $80 more than I normally spend on a kit like this. When all said this P51 will have cost me about $230. The Hangar 9 is $254. I will save about $24 making my time worth about $2 per hour (not counting the trips to the hooby shop).
She will fly this weekend. I will let you know how she flys.
(in reply to Ken Bryant)
       Post #: 54
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 10/31/2006 1:45:41 PM
RC_DESI
Status: offline
quote:
ORIGINAL: GotSky
arvind-rao
Must have been just an issue in the planes I got (even the replacement tail had a gap) I agree on swaping out the hinges & I used the Hanger9 CA ones I already had
Also I am not sure on what kinda of f/g they use for cowl. I can see the cloth on the back, but the plastic flexes a lot & cracks very easily on doing so. It looks like ABS plastic with a glass backing
Attached are some pics showing the gap/max deflection my plane has...
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by arvind_rao -- 10/31/2006 1:49:28 PM >
(in reply to GotSky)
       Post #: 55
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/1/2006 3:40:57 AM
GotSky
Status: online
arvindo_rao
Yes I can see how the gap would be an issue on yours. I would bet this is from the soft balsa that they were using. When the covering went on it most likely flexed the trailing edge inward. Hopefully on the new ones this won't be an issue. You definitely want to seal that baby with some hing tape or clear monokote,, Good luck
       Post #: 56
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/1/2006 3:54:37 AM
opjose
Status: offline
I'd consider cutting the CA hinges and using those nice dowel type hinges with the built in hinge points instead.
That should give you the desired travel, but you would be able to reduce the gap.
As Gotsky stated, you'd want to seal the hinge never the less.
_____________________________
Build em'', fly em'', crash em'' and build more.
       Post #: 57
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/6/2006 9:26:03 AM
pilot727
Status: offline
I can understand what you are doing and the time it takes you to get set up again and to improve on the issues that have been made but i am a very happy customer and surely will buy again, also you are here doing something about it and that has to count for some thing, you already know alot of the things that need to be done but it is going to take time to get all the bugs out but your facing it head on and most important is that you are listening to the pilots and what they have to say as no one knows these things better then us pilots, i watched the p-38 film and the grass runway was rough, my twinstar a nice twin, i have noticed that flying off of the grass field has split some of the sheeting from all them bumps, i have never had a problem on dirt or tar but on a rough grass field it is very hard on a twin engine airplane, nitro your doing a great job keep up the good work.
       Post #: 58
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/7/2006 1:26:39 AM
LDM
Status: offline
This is a simple one to fix -pics need to match the plane , the P47 -you click on it and it does not match the plane , and the P40 color scheme is off as you scroll down , what color is it ? , Do you make your own versions of the 73" p40 or do you have the CMP or both ?
Seems like one of yours is brown on Tan and another is green on gray in the 73"size ,The brown on tan looks like a willshobby versions , can you let me know please .
I have had the 60 " size P40 very nice plane originally released by hobby people as Sportman avaition in a very ugly scheme , yours is much better but I wish you left the retracts off added the proper rails for rotating gear and allowed the purchaser to add rotating gear , the P51 style gear kills this otherwise very nice looking plane .
LDM
       Post #: 59
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/7/2006 4:03:16 PM
cessna4me
Status: offline
No complaint here,but i wanted to say that for the money you are getting a lot of airplane love my edge and looking forward to the cessna 310 twin have always loved this plane but not the building thanks for putting one out,,,Ron
       Post #: 60
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/7/2006 8:57:29 PM
arck
Status: offline
Dear Nitro staff why couldn't you shipp planes outside US, I live in south america and had bought several parts and planes from other stores in USA, they ship the planes thru a forwarding company or usps with no problem, why you cant?
wm
Dual Ace,Challenger II P,messerschmit .46,spitfire .25,sirius hot,upstar glid.,Fan Trainer,VDiamond P, blade cx2,Revo3.3 et
       Post #: 61
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/7/2006 9:48:42 PM
rcavi8ter
Status: offline
One of the things i have noticed on some of the aircraft that I was interested in was that you posted pictures of the Type of aircraft that appears to be well done with a good outline but then that is not even one that you sell. Case and point. The Super Chipmunk. Also you show alot of color schemes for like the Cessna 310 and the Long EZ but what scheme does the kit actually come in? I have a buddy that has you little Extra and I think it is a great little kit for the money but improve the website to make shopping easier and then you can have some of my money
Chris Puckett
(in reply to arck)
       Post #: 62
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/8/2006 3:19:11 AM
stanordave
Status: offline
I love NitroPlanes. I've bought 12 motors from you. Can't beat the price and fast service but...too many shipping errors. I've gotten a shipment missing items that were backordered but never told that. Eventually only got 1/2 of what was paid for. ordered a brushless ESC and got a brushed one, etc. Need to get a better crosscheck on order before shipment.
(in reply to rcavi8ter)
       Post #: 63
RE: WHAT'S WRONG WITH NITROPLANES.COM? - 11/8/2006 9:01:59 AM
GotSky
Status: online
NitroStaff1
I see that you now have the fuselage set, Tail feathers and cowl in stock for the YAK 52. I know you said there is no way to pick items up this time of year so I was hoping that you could send these items to me via UPS or Fedex. Thank you again for your time...
(in reply to nitrostaff1)
       Post #: 64
