Methanol For Home Brew
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Methanol For Home Brew
Page: [1]
Login
Methanol For Home Brew - 10/21/2006 9:32:36 AM
efish
Status: offline
Hi everyone, I moved into the larger glow engines recently (.40 and up) and my fuel cost is burning a hole in my wallet! I can burn what used to be a week's supply for my 1/2A planes in a couple of flights!
Anyhow, I've been reading through the "Home-brew fuel" thread with much interest. Just one question:
About the only source of methanol I can find locally is stuff from hardware/paint shops being sold as "Methanol Spirit". Actually, I've been buying the stuff for years to thin epoxy and prep surfaces before gluing. Even used it in my alcohol camping stove.
Of course when I ask, the shop swears that its methanol. Unforunately, it's obviously been repackaged and there are no markings on the cans.
My question is: is it safe for me to try mixing up a batch with this "Methanol Spirit" stuff? I will strain and filter while mixing and there's always a filter in my fuel feed lines, but is there any chance I'll damage the engine?
I will probaly be trying try low or no nitro with 20% castor and use tach readings to check performance.
Thanks.
       Post #: 1
RE: Methanol For Home Brew - 10/21/2006 4:25:46 PM
hpi apollo
Status: offline
your best bet to to track down a shop that has some pure methanol in a 5 gallon drum, that stuff at the hardware store usually has random chemicals mixed in with it, i pay $21/5 gallons, called around for motorcycle shops that might carry some methanol and nitro, or be able to order it for you
_____________________________
95% of statistics are made up on the spot
(in reply to efish)
       Post #: 2
RE: Methanol For Home Brew - 10/22/2006 11:37:06 AM
efish
Status: offline
Thanks, was just hoping for a quick and easy way to do this since I pass my regular hardware shop just about everyday.
Will try and find a 5 gallon drum - that would probably be a lot cheaper.
(in reply to hpi apollo)
       Post #: 3
RE: Methanol For Home Brew - 10/22/2006 2:21:40 PM
RCPAUL
Status: offline
Are you sure that what you've been buying is not methylated spirit? This is the same as denatured alcohol - ethanol with a little methanol or other chemical added to make it non-drinkable. It can be used in camp stoves.
Paul
Gosh, model airplanes are not a matter of life and death --- they're more important than that!
(in reply to efish)
       Post #: 4
RE: Methanol For Home Brew - 10/22/2006 4:53:46 PM
efish
Status: offline
Hi Paul, funny thing is that I've always thought it was methylated spirit and used it as such.
But the label on the can/bottle says "Methanol Spirit" and the shop seems to think it's 100% methanol.
Will start looking for a methanol supplier, but in a pinch, would running methylated spirit (if that's even possible), or questionably pure methanol damage an engine?
Thanks.
(in reply to RCPAUL)
       Post #: 5
RE: Methanol For Home Brew - 10/24/2006 3:03:50 AM
hpi apollo
Status: offline
use methanol, nothing else, use what engines are intended to run on and you will no have problems, there are other chemicals in that hardware alcohol too
(in reply to efish)
       Post #: 6
RE: Methanol For Home Brew - 10/24/2006 4:04:12 AM
efish
Status: offline
Yeah, that's what I thought, HPI_Apollo. Thanks.
It's holiday period here right now, so I'll resume my "great methanol" search tommorrow. Thanks again.
       Post #: 7
RE: Methanol For Home Brew - 10/24/2006 9:10:07 PM
Sport_Pilot
Status: offline
To call it a spirit implies there is only a small amount. A ghost of itself. Do an internet yellow page search for VP Racing Fuel, I don't know if they ship to Singapore or not, or if this is the best way to get methanol in your area, but it wouldn't hurt to e-mail them and ask.
“I Saw Elvis at 1000 Feet” John Force
(in reply to efish)
       Post #: 8
RE: Methanol For Home Brew - 11/2/2006 1:45:34 PM
speedster 1919
Status: offline
Sport pilot He's in Sigapore. I doubt they would have a drag racing outlet. I know in other parts of the world methanol is called something else.
Hey Buddy -That was the most spectacular crash I've ever seen , That rolling cart wheel with parts slinging out was cool...
(in reply to Sport_Pilot)
       Post #: 9
RE: Methanol For Home Brew - 11/2/2006 5:23:25 PM
efish
Status: offline
Thanks Speedster. Have tracked down a possible source that I will be checking out tommorrow.
Apparently, Go-Karts used to run on methanol and nitro, but these days, I understand that they all run on regular petrol.
(in reply to speedster 1919)
       Post #: 10
RE: Methanol For Home Brew - 11/2/2006 7:55:21 PM
Sport_Pilot
Status: offline
quote:
ORIGINAL: speedster 1919
Which is why I mentioned shipping. Did you not read that?
       Post #: 11
RE: Methanol For Home Brew - 11/2/2006 7:57:00 PM
Sport_Pilot
Status: offline
Go Karts run on gas. Racing karts run on methanol. I don't think there are any that use nitro, except maybe a cheater or two.
       Post #: 12
RE: Methanol For Home Brew - 1/28/2007 4:09:30 PM
Fuel Dinosaur
Status: offline
I would check the MSDS safety data sheet for the methanol to make sure the purity and major contaminants, like water, ethanol, etc. When you find out their supplier, you can find out either online or in the store catalog the exact description of what they are supplying you. I agree that a kart racing place or motorcycle shop (or speed or racing shop) is fine for a local supply. Do not forget about local industries that either have, or can get good methanol for you. VP Racing sells M-1 methanol in 55 gallon drums for club use. My current 110 gallons are 99.985% pure, okay a little overkill, but what can you expect from someone with a chemistry degree in their bag of degrees?
In a local speed shop, I did find some really clean nitromethane. VP has that too, but for a 30 gallon barrel, you have to bring your firstborn with you when you pick it up. Not. Many modelers have come to the conclusion that with small quantities of methanol, relatively expensive oils and very expensive nitromethane, and the wonders of hazmat shipping costs, you really have to use a lot of fuel to justify making your own. Having mixed all my fuels for longer than I care to remember, I have never known otherwise. A few pilots gave me some fuel to test, including some green all synthetic stuff. I just LOVE to see my engines smoke like that after a run.
       Post #: 13
RE: Methanol For Home Brew - 1/30/2007 7:23:11 AM
efish
Status: offline
Thanks for that Fuel Dinosuar, with some difficulty, I finally managed to get some methanol from the "friend-of-the-wife-of-a-fellow-flier" who happens to run a chemical factory.
Now my the only thing I can't seem to find is Nitro. There are no speed shops that I know about locally.
Was told that post 9/11, it's now a controlled substance here, but there are persistent rumors of limited availability from various sources. Will try to track it down, but failing which, I'll try some 0% and/or cut some of my 5% with the stuff.
At one time, I was burning about a gallon a week so premixed fuel cost was substantial. I've about halved that now by flying smaller engines less frequently, but 2 gallons a month still costs a bit.
Thanks anyhow.
(in reply to Fuel Dinosaur)
       Post #: 14
RE: Methanol For Home Brew - 1/30/2007 1:34:12 PM
Fuel Dinosaur
Status: offline
Re: nitromethane- A controlled substance is quite different from a banned or illegal substance in the case of nitromethane. If there is not a complete ban on nitromethane in your country, a chemist type person can probably obtain the nitromethane in small quantities, like gallons or 5 gallon quantities. I have about 30 gallons or so right now and did have to explain that I was using the nitromethane as a solvent and for model fuels. It did not hurt that I have a degree in chemistry a
