bobzilla
Joined: 8/4/2004 From: Henderson, NV, USA Status: offline
The only warning I have is that "captured" air will put significant more air pressure inside the cabin...and a weak attached hatch/canopy will usually eject with force. I have had it happened on my 2 30% yaks..as the opening in the YAK 54 is huge hole and the air getting to the inside of the fuselage just is too much for the hatch. One hatch blew off, hit the elevator which naturally, downed the yak..Aerobatic Models sold me a replacement plane at cost. (sweet) so..now, I have little air vents along side of hatch and in back..that lets that air move on thru and out..thus lowering the pressure.. something you will have to CAD up also..(nice).. bobz p.s. I thinking..what about an semi enclosed area that the air enters, flows over the esc..then out the same type of duct you have designed only backwards?
