RE: Extra 300 is born !
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: Extra 300 is born !
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Extra 300 is born ! - 11/4/2006 4:54:43 PM
as722
Status: offline
The turtle deck is now ready to be glued in place. I placed the turtle deck on the fuse as well as the rudder just for the picture. Time to go back to the basement and finish the rudder and turtle deck, next will be the horizontal stabs.
Albert
Click to see fullsize image.
Click for fullsize
_____________________________
Carden Aircraft
(in reply to as722)
       Post #: 26
RE: Extra 300 is born ! - 11/5/2006 10:30:05 PM
as722
Status: offline
Some more pictures of the fuse, notice the holes on the phenolic they look cool if nothing else.
Click for fullsize
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 27
RE: Extra 300 is born ! - 11/5/2006 10:36:32 PM
as722
Status: offline
getting the stabs ready to sheet. I use a foam cutter from Michael's arts and crafts to cut the servo wire exit hole, because I'll be using a vaccum bagger I capped the slot made by the hot wire with a piece of balsa 1/8" wide by 1/4" deep.
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 28
RE: Extra 300 is born ! - 11/5/2006 10:39:59 PM
as722
Status: offline
Horizontal stabs are now ready to sheet which by the way is very easy since all of cardens balsa sheets come trued out of the box !
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 29
RE: Extra 300 is born ! - 11/5/2006 10:53:32 PM
wgeffon
Status: offline
Looks awesome Albert.
Wayne
(in reply to as722)
       Post #: 30
RE: Extra 300 is born ! - 11/5/2006 11:59:33 PM
DMichael
Status: offline
Albert,
Tell me more about this foam cutter from Michaels.
Dave
Team ZDZ
www.rcshowcase.com
(in reply to wgeffon)
       Post #: 31
RE: Extra 300 is born ! - 11/6/2006 12:57:07 AM
as722
Status: offline
Dave,
I'll take a picture of the actual cutter later and post it. It basically works just like a soldering gun except that it accepts much smaller piano wire. It also heats up instantly.
Albert
Carden Aircraft
(in reply to DMichael)
       Post #: 32
RE: Extra 300 is born ! - 11/6/2006 1:40:31 PM
Bobt2
Status: offline
albert, do you think you saved anything with the holes in the tube socket? i would think there may be some bending in this area with flight loads.
(in reply to as722)
       Post #: 33
RE: Extra 300 is born ! - 11/6/2006 3:18:32 PM
wgeffon
Status: offline
quote:
ORIGINAL: Bobt2
Nope.
The tube is completely removed inside the motor box on my Carden 260. ZERO issues.
The motor box and side formers do not allow any movement in this area.
It was a 1 oz savings for us. We did it for the cool factor more than anything else.
Click for fullsize
Click for fullsize
Wayne
(in reply to Bobt2)
       Post #: 34
RE: Extra 300 is born ! - 11/6/2006 4:16:32 PM
Bobt2
Status: offline
interesting, would you do the same thing if you were using a cf tube?
       Post #: 35
RE: Extra 300 is born ! - 11/6/2006 4:36:26 PM
wgeffon
Status: offline
Yes. Why not?
Wayne
(in reply to Bobt2)
       Post #: 36
RE: Extra 300 is born ! - 11/6/2006 4:44:22 PM
zzw26n
Status: offline
Not the correct Thread; but Congratulations Wayne, nice job in Tucson Shootout. Sounds like that 260 is a keeper.
Ward
       Post #: 37
RE: Extra 300 is born ! - 11/6/2006 5:27:07 PM
Flyfalcons
Status: offline
I would be willing to bet that most of the bending action is where the fuse and wing meet, not in the center of the wing tube.
Ryan Winslow
Cub flying - the new EXTREME SPORT!!! (evarrr)
(in reply to zzw26n)
       Post #: 38
RE: Extra 300 is born ! - 11/6/2006 9:11:33 PM
as722
Status: offline
I did it for the cool looks more than anything, the weight savings was nothing.
Albert
Carden Aircraft
(in reply to Flyfalcons)
       Post #: 39
RE: Extra 300 is born ! - 11/7/2006 2:51:45 AM
