RE: Extra 300 is born !
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: Extra 300 is born !
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Extra 300 is born ! - 11/11/2006 11:56:43 PM
as722
Status: offline
The 300 is coming along great and if everything goes as plan I will be covering in a few weeks. Here's a pic. of the hard points that will be sitting on top of the "l" brackets to hold the stabs in place.
Click to see fullsize image.
Click for fullsize
_____________________________
Carden Aircraft
(in reply to as722)
       Post #: 51
RE: Extra 300 is born ! - 11/12/2006 12:02:28 AM
as722
Status: offline
As always I used robart hinges along with their jig and will be using rc-56 white glue to glue them in. A 3/16" brass tube was used instead of a drill bit to drill clean holes!
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 52
RE: Extra 300 is born ! - 11/12/2006 12:05:34 AM
as722
Status: offline
Bevels on elevators and stabs.
Click for fullsize
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 53
RE: Extra 300 is born ! - 11/12/2006 12:14:19 AM
as722
Status: offline
Here's something I've been doing to "hide" the hinges. I use a dremel sanding drum and sand a "half moon" on every hinge pocket after monokoted I use a soldering gun to burn a hole through the monokote.
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 54
RE: Extra 300 is born ! - 11/12/2006 12:16:36 AM
as722
Status: offline
Tail wheel plate and bottom of fuse pic.
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 55
RE: Extra 300 is born ! - 11/12/2006 12:18:21 AM
as722
Status: offline
Top deck in vaccum bag.
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 56
RE: Extra 300 is born ! - 11/12/2006 12:20:52 AM
as722
Status: offline
Starting to look like an airplane !
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 57
RE: Extra 300 is born ! - 11/12/2006 1:43:01 AM
zzw26n
Status: offline
Albert,
Thanks for the photo's, I can't tell you how much value they add to the understanding of the build. After watching a couple of these, I feel like I might be able to do this. It will take me a year, but it would be fun.
Keep up the great work Albert!
Ward
(in reply to as722)
       Post #: 58
RE: Extra 300 is born ! - 11/12/2006 2:20:55 AM
as722
Status: offline
Ward,
No problem with the amount of knowledge here on rcu as well as other forums building one of these isn't as hard any more.
Albert
< Message edited by as722 -- 11/12/2006 3:12:57 PM >
Carden Aircraft
(in reply to zzw26n)
       Post #: 59
RE: Extra 300 is born ! - 11/12/2006 3:20:32 PM
as722
Status: offline
I made some templates this morning and hollowed the top deck, there was a savings of .9 oz which brings the total foam savings to 3 oz on the hole fuse. There's two reasons for cutting the foam out of the top deck.
1. It makes it easier to pull or push the sides for that perfect fit ( actually it might be a 1/32" off at the most )
2. It will allow me to mount the tank right on top of the wing tube, other wise it would hit the bottom of the top deck.
Albert
Click for fullsize
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to as722)
       Post #: 60
RE: Extra 300 is born ! - 11/12/2006 4:06:31 PM
OnTheEdge
Status: offline
Albert, are going to build the cockpit like the plans or make it an open truss on this plane?
Avoid zen aerobatics...when the ground........and the plane.......become as one.
(in reply to as722)
       Post #: 61
RE: Extra 300 is born ! - 11/12/2006 4:22:54 PM
as722
Status: offline
I don't know yet, I've always tought it would look cool to have two instrument panels and two pilots but that would add a lot of weight so I'll probably be open truss.
Albert
Carden Aircraft
(in reply to OnTheEdge)
       Post #: 62
RE: Extra 300 is born ! - 11/12/2006 5:15:12 PM
OnTheEdge
Status: offline
From the photo above, it looks like you'd have to modify the floor to fit around the tank anyway.
(in reply to as722)
       Post #: 63
RE: Extra 300 is born ! - 11/15/2006 2:40:26 AM
as722
Status: offline
I feel like I got nothing done today but some days are not as productive as others. The hatch frame work is done and I even decided to get a little creative with the back plate of the hatch.
Click for fullsize
Click for fullsize
Click for fullsize
Carden Aircraft
       Post #: 64
