supertib
comparing the Picco to Sirio.... the Picco has a touchier trigger, doesn't take much throttle at all to get onto pipe, very little trigger input results in very big power... the Picco feels insanely snappy and extremely responsive... Some people may complain the motor triggers too much, and feels like a light switch.. very very good motor if you like to blip the trigger, as nothing carries pop like a Picco does......... the Sirio on the other hand is very smooth and linear, it requires a significant amount of trigger input to get things rolling, the motor is deceptively torquey tho, it does not feel explosive like the Picco does, but if you open the trigger up it will blow the tires off just as violently as the Picco does............. With the Sirio I felt I lacked the crisp throttle response I was used to with the Jammin motor... That may be why I am saying the Sirio feels mild.....the Sirio is suited to someone who likes a smooth motor, and the Picco is good for someone who likes ultra crisp throttle response.... both have similar power, but they feel worlds different driving then back to back...... If you drove a JPX back to back with a Sirio you would swear the JPX has way more power because of the way it triggers.... The modified JPX feels violent compared to the Sirio.... Hair Trigger vs Smooth Trigger !!!! both outstanding motors
< Message edited by supertib -- 5/29/2008 7:04:55 PM >
_____________________________
seeing is believing !
