RE: 8ight Truggy
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: 8ight Truggy Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: 8ight Truggy - 1/14/2008 9:34:37 PM
os v-spec
Status: offline
Hey INTEGRA...looks good man....i cant wait to race you this summer
_____________________________
Mugen MBX5T prospec
V-Sepc .21
(in reply to INTEGRA)
       Post #: 151
RE: 8ight Truggy - 1/14/2008 9:35:34 PM
INTEGRA
Status: offline
quote:
ORIGINAL: os v-spec
Its ON like Donkey Kong.
http://s150.photobucket.com/albums/s102/davidmoxley123/
http://s49.photobucket.com/albums/f285/TrUInTeGrA123/
(in reply to os v-spec)
       Post #: 152
RE: 8ight Truggy - 1/15/2008 12:39:56 AM
luisev
Status: offline
Looks great buddy...
Go Tech, JConcepts, Upgrade RC Dealer
www.rcloverz.com
       Post #: 153
RE: 8ight Truggy - 1/15/2008 2:53:44 AM
luisev
Status: offline
New Losi upgraded parts for the 8ight...
http://www.neobuggy.net/modules/news/article.php?storyid=3165
www.rcloverz.com
(in reply to luisev)
       Post #: 154
RE: 8ight Truggy - 1/15/2008 2:58:32 AM
INTEGRA
Status: offline
im likin it...a whole .2 seconds average faster MPH then the X2......Muhahaha.
       Post #: 155
RE: 8ight Truggy - 1/19/2008 2:47:15 PM
Th3pwn3r
Status: offline
Well, it was a very bad day for my 8ight last night First off my buddy was talking trash and he got on the track probably 30 seconds before me so I quickly caught up and as we went through the woops and into our jump in front of our pit/driver stand I landed on him at probably 15 mph and it wasn't a hard hit at all and CRACK, it rang through out the place and I was like no way...so I assess the problem. I found my Lunsford Titanium hinge pin curled like an antenna tube but nothing else broke(What a waste of 30 bucks on the kit). So I go and replace it with a steel hinge pin and I'm running again. I'm putting down some good laps with no crashes and I didn't hit anything and all the sudden I'm like "Aww crap I have no steering." so I tell a marshal to bring it in and I find out my left front spindle snapped(UGH!). I replace the left spindle and I'm running clean again, no accidents and no bad landings and I have no steering yet again! WHAT THE H3LL!? So I pit in and I find out my JR 9100S won't hold it's center line anymore and it's done. I think it was the cold because it was 0 degrees last night so I'm guessing that's why the problems occured.
On another hand when I wasn't broken I sure did throw down some decent laps and I was ahead of everyone else when I wasn't broken. My rear end gets squirley if I'm not careful with the throttle(running 5000W in the diff) and because it's kicking to a side I'm going to run 7000w any tips people? My track is high bite but I still spin the tires.
For steering I had plenty of turning(Until I snapped a spindle and my servo gave out) running 2(?) degrees of toe out and 2 degrees of negative camber on the front, 1 degree of negative camber on the rear. The trug felt very planted until I would spin on powering through the turns.
< Message edited by Th3pwn3r -- 1/19/2008 2:51:08 PM >
I too say no to shelf queens.
       Post #: 156
RE: 8ight Truggy - 1/20/2008 4:28:15 AM
Th3pwn3r
Status: offline
Well, after inspection I found out that my servo horn stripped out and that my 9100S was fine, whew!
(in reply to Th3pwn3r)
       Post #: 157
RE: 8ight Truggy - 1/20/2008 7:24:31 PM
INTEGRA
Status: offline
quote:
ORIGINAL: Th3pwn3r
plastic horn...>>DIRTY. ...get a nice allum 1 from Hanger 9.
       Post #: 158
RE: 8ight Truggy - 1/20/2008 8:31:37 PM
Th3pwn3r
Status: offline
quote:
ORIGINAL: INTEGRA
quote:
ORIGINAL: Th3pwn3r
I already picked up and installed an aluminum horn
       Post #: 159
RE: 8ight Truggy - 1/20/2008 8:44:25 PM
fsbb33
Status: offline
anyone know where i can find an aluminum horn for my hitec 5955tg servo for my 8ight t?
       Post #: 160
RE: 8ight Truggy - 1/20/2008 10:02:32 PM
INTEGRA
Status: offline
quote:
ORIGINAL: fsbb33
A-main....i like hanger 9 horns the best...specially the HD versions....but i see they dont make 1 for Hitec...hrmm...go with w/e then......dynamite or the hitec alloy horn.
(in reply to fsbb33)
       Post #: 161
RE: 8ight Truggy - 1/20/2008 10:54:09 PM
2farback
Status: offline
fsbb33
try tiltedrc (changed name from bmainhobbies). Part number LOSA99033.
They may be out of stock, but that is where I found mine.
http://www.tiltedrc.com/product_info.php?cPath=65_66_74&products_id=2050
       Post #: 162
RE: 8ight Truggy - 1/21/2008 2:41:37 AM
Th3pwn3r
Status: offline
I switched from 5000w in the rear to 7000w so I'll see how that works this coming Thursday.
(in reply to 2farback)
       Post #: 163
RE: 8ight Truggy - 1/21/2008 2:57:00 PM
slayerphonics
Status: offline
Best thing i ever did to my 8ight was lower the back diff fluid
I was running 5k in the rear, it just wanted to throw the rear end around
I lowered it to 3k it helped soooo much i may even go to 2k
There's a right way and wrong way to do everything and the wrong way is trying to make everybody else do it the right way
       Post #: 164
RE: 8ight Truggy - 1/21/2008 4:06:45 PM
Th3pwn3r
Status: offline
The only thing I'd be worried about is it unloading to one wheel so fast and causing the trug to pull off to the side like it was doing to me with the 5k w. I'm going to pick up some 2k and 3k w and bring them to the track with me and see what happens. I'll let everyone know. Adam Drake is running 3k in the rear though so that's probably my best bet lol. I'm also using non offset pro lines so a wider stance of offset wheels might help out a bit, we'll see though!
(in reply to slayerphonics)
       Post #: 165
RE: 8ight Truggy - 1/21/2008 11:08:22 PM
