Th3pwn3r
Joined: 12/3/2007 From: Chicago Ridge, IL, USA Status: offline
quote:
ORIGINAL: unluckylonestar what everyone's setup on there 8t's, fluid, shock oil, suspension settings, tires, etc. I almost don't want to say lol. For Diffs: Front-7,000w Center-10,000w Rear-3,000w Suspension Shafts level front and back Front springs-Black Rear springs-Gray Front Camber-2 degrees negative Rear Camber-1 degree negative Front Toe-2 degrees out Rear Toe-1 degree out Front Shock Oil-40w Rear Shock Oil-40w Tires/wheels Pro-Line LPR Wheels/w Holeshots 0degree offset- They hook up well but bumps while turning will cause you to roll over. Team-Losi XTT/w Team Losi white wheels 1/2'' Offset(?)- These provide good turning through bumps but don't hook up too well. Pro-Line LPR Wheels/w Holeshots 1/2'' Offset- Best of both worlds, they hook up great on my local and the added stability stops roll-overs. JR 9100S servos for steering and throttle/brake. Mach 427 Engine(I don't really need more speed...just yet ) Stock pipe and header(Changing when I get a new engine) Adjustable front hinge pin brace Ti Hinge pins all around
< Message edited by Th3pwn3r -- 1/28/2008 9:56:36 PM >
_____________________________
I too say no to shelf queens.
