Hydro Junkie
WA, USA Status: offline
Lake pirate, slot the rear wing screw hole in both tails. Be sure they have a slight radius so the rear wing screws can move without binding so you can adjust the angle of the wing. Just remember, THE REAR WING IS FOR FINE TUNING THE BOAT'S ATTITUDE, NOT SUPPORTING THE REAR OF THE BOAT. The rear of the boat is supported by the prop and air pressure UNDER THE BOAT AND NOT UNDER THE WING. I would recommend moving weight forward(primarily the radio gear) and shimming the strut before adding weight. If you must add weight, use stick on weights on the front of the sponson decks, then drill an access hole in the sponson and add epoxy and lead shot equal to the weight of the stick on weights. I think you will find you will need less wieght that way.
< Message edited by Hydro Junkie -- 7/19/2007 4:29:11 AM >
