paf
Joined: 11/20/2002 From: New York, NY, USA Status: offline
I had one bracket start cracking on my Cap years ago. It was due to slight mis-alignment of the surfaces. The bolts were slightly stretching the plastic. It also seems that the stab tube always has a little play in it and the stabs can move up/down slightly. This movement gets transfered to the L bracket as well, so over time, it could weaken it enough to fail. Wayne - the first hand failures you know about - did the owners inspect the brackets regularly, or did they leave their stabs on all the time and maybe overlooked a developing crack ? P.
