RE: Extra 300 Prototype #2
Tower Hobbies
Logged in as Guest
  Printable Version
Universal Cradle System
Seller:  flyn4wrd
Details:   $175.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: Extra 300 Prototype #2
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: Extra 300 Prototype #2 - 4/9/2007 11:41:28 PM
RobT
Status: offline
Final weight with everything except for wing / hatch screws, vinyl, and fuel = 37 lbs 1.5 oz
Break Down
Fuse = 26 lbs 12.5 oz
Right Wing = 3 lbs .7 oz
Left Wing = 2 lbs 15.6 oz
Wing Tube = 1 lb 1.1 oz
Canopy = 1 lb 11.2 oz
Right Stab = 11.5 oz
Left Stab and Tube = 12.9 oz (I leave the tube in so I do not have to find the holes for the 6-32 bolt)
8611's everywhere
2 LiPo 3850 packs with Smart Fly fail safe Regs on receiver, 1 2000 LiPo on ignition with smart fly ignition reg.
1 JR receiver.
Monokoted, painted canopy, 1 piece cowl
DA 150 with K&S cans
Tru Turn Spinner, airmodels 2 blade prop for test flight / weigh in.
Stock Gear
< Message edited by RobT -- 4/10/2007 1:46:35 PM >
(in reply to RobT)
       Post #: 151
RE: Extra 300 Prototype #2 - 4/10/2007 12:15:28 AM
hoverVT
Status: offline
RobT , very nice job and excellent scheme. The lines are very clean and looks great. I can not wait to get some more flights on mine. Great Job! Tony
_____________________________
Electrics just don't smell right!!!
(in reply to RobT)
       Post #: 152
RE: Extra 300 Prototype #2 - 4/10/2007 3:48:27 AM
OnTheEdge
Status: offline
Congrats Rob! The plane looks great! Can't wait to see it in person.
.....Mark
Avoid zen aerobatics...when the ground........and the plane.......become as one.
(in reply to hoverVT)
       Post #: 153
RE: Extra 300 Prototype #2 - 4/10/2007 5:52:16 AM
DMichael
Status: offline
OK boys, here's mine put together after the paint. I will try to get it together outside in the next day or two to get some good shots. First picture is without the gear installed. Tonight I put everything back in and got a weight.
Mine looks like it is coming in around 36.5lbs as is. This includes a ZDZ Super 160, Mej 32-10, Pete's model carbon spinner, MTW 110Ks, throttle servo, choke servo, 2 servos on each aileron, one on each elevator, two on the rudder, two receivers, two Fromeco 4800 LiIon, two Fromeco regulators, one Fromeco 2600 on iginition and allows for a 4oz pilot. I did "standard" lightening - all of the holes in the plywood motor box area and such, lightening holes in belly pan and rudder. Stock gear, Graphtec tailwheel and fully sheeted sides.
Based on discussions with Rob, Albert, Walt and Wayne as we have been building these first kits, I am confident that this plane will be coming in around 36-38lbs with cannisters if using these "standard" lightening techniques and not going crazy. We are all in that range.
Plane seems to be coming in a bit noseheavy for all of us. This is excellent as you can compensate by moving batteries and much preferable to a tailheavy condition. This plane does not seem to need a pull-pull rudder configuration (more good news).
On top of all of this it has perhaps the most beautiful lines of any giant scale plane (my opinion). The only one in its class is Dennis's 330. This plane uses the same cowl and the sleek shape of the canopy reminds me of the 330's, only longer.
If you are considering one of these- you will not be disappointed.
Dave Michael
Click to see fullsize image.
Click for fullsize
Click for fullsize
Team ZDZ
www.rcshowcase.com
(in reply to OnTheEdge)
       Post #: 154
RE: Extra 300 Prototype #2 - 4/10/2007 1:03:49 PM
OnTheEdge
Status: offline
I really like your scheme Dave. Looks good. The paint/ultracote match looks great.
Best of luck with it!
(in reply to DMichael)
       Post #: 155
RE: Extra 300 Prototype #2 - 4/10/2007 1:45:36 PM
RobT
Status: offline
Dave,
Your 300 looks great!
I cannot agree more with everything you said. Dennis's 330 is amazing as you know, but when you fly the 300 it will blow the 330 away.
After reading your post I realize I should have said two servos per aileron, 2 on rudder in the tail, and choke servos are in mine.
Rob
       Post #: 156
RE: Extra 300 Prototype #2 - 4/11/2007 4:17:28 PM
T. Bob
Status: offline
Great Scheme Dave.
"This plane has no limits as to performance with this engine except vertical"
(in reply to RobT)
       Post #: 157
RE: Extra 300 Prototype #2 - 4/11/2007 6:35:06 PM
DMichael
Status: offline
Thanks for the nice words guys. I know Mark and Rob will be seeing it this summer- maybe we'll see you out there sometime too, T Bob.
Team ZDZ
www.rcshowcase.com
(in reply to T. Bob)
       Post #: 158
RE: Extra 300 Prototype #2 - 4/12/2007 12:18:27 AM
OnTheEdge
Status: offline
quote:
ORIGINAL: DMichael
Hmmm, Just "seeing it"
       Post #: 159
RE: Extra 300 Prototype #2 - 4/12/2007 2:44:43 AM
DMichael
Status: offline
quote:
ORIGINAL: OnTheEdge
quote:
ORIGINAL: DMichael
You never know......
Team ZDZ
www.rcshowcase.com
       Post #: 160
RE: Extra 300 Prototype #2 - 4/12/2007 8:22:57 PM
hoverVT
Status: offline
Dave, Sweet!!!! That is a really great looking plane. Send some more pics with the graphix on it. Thanks Tony
       Post #: 161
RE: Extra 300 Prototype #2 - 4/12/2007 9:04:31 PM
DMichael
Status: offline
Hey Tony- you see that box I have under the tail? <VBG>
Once I get the radio graphics on it I'll send them right over!
Just havin' some more fun with ya.
Dave
Team ZDZ
www.rcshowcase.com
       Post #: 162
RE: Extra 300 Prototype #2 - 5/13/2007 1:27:23 PM
RobT
Status: offline
Need to add graphics still, but it is comming along . . .
Click for fullsize
       Post #: 163
RE: Extra 300 Prototype #2 - 5/13/2007 1:50:47 PM
Bobt2
Status: offline
i like these better
Click for fullsize
Click for fullsize
(in reply to RobT)
       Post #: 164
