jett 90 lx
Tower Hobbies
Logged in as Guest
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> jett 90 lx
Page: [1]
Login
jett 90 lx - 10/24/2006 1:04:37 AM
SACKRC
Status: offline
Got my motor today. Took it apart, always do on new motor. The lower rod dosnt have oil holes. also the transfere ports on the top are a negetive angle pointing down. Is this standard. usually the transfere are level or up and towards the back to the boost. Appreciate some input. rich b. thanks.
       Post #: 1
RE: jett 90 lx - 10/24/2006 3:17:06 PM
bob27s
Status: offline
Hi Rich...
Thanks for writing.
First off..... every Jett engine is run at the factory before you receive it. It is not your typical engine - and Dub takes great care at assembly and testing to ensure every engine meets performance criteria before it is delivered. The shop run addresses the initial risk to the rod, and the carb low speed mixture is pre-set so the engine is ready for the final bench break-in on your end.
Disassembling the new Jett engine is generally not a good idea. No general risk here, but take care in re-assembly. Take great care to ensure the head bolts are properly torqued down, and re-check the bolt torque after the first couple of engine runs.
The engine design features you describe appear accurate, and I will verify this with Dub. The 90LX porting is indeed unique, and is different from the standard SJ-90L in a few ways.
Bob
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to SACKRC)
       Post #: 2
RE: jett 90 lx - 10/25/2006 1:45:23 AM
SACKRC
Status: offline
Bob appreciate your reply. Dont care much about the ports. Would like to no if the rod at lower end should have oil holes.. mine do not. thanks again. Enjoy reading your many comments on extreme prop plane. You have a great deal of knowledge and input tfor the guy. One of the reasons Im concerned is . I have a 40 and 50 jett also and they have oil holes. rich b.
(in reply to bob27s)
       Post #: 3
RE: jett 90 lx - 10/25/2006 10:04:51 PM
jettlag
Status: offline
I love to answer these kind of questions, which by the way are good ones. Nevertheless, I get to lecture a bit:
First. I have a saying: If you assume the obvious you are probaby wrong. It is obvious that rods need oil holes, right. Well, guess what? They don't. The majority of the pumping is done by the motion of the rod moving up and down on the crank journal. Sort of like flopping your underarms and hands to make crude sounds in Jr. High....Every time it flops from the top of the journal to the bottom it creates a vacuum in the gap, sucking in more oil.
Also, the majority of rod breaks are through the oil holes, so we learned (by not listening to the "Experts" that you do not need the holes and that, in fact, the holes make them weaker.
This brings us another of my sayings, " People who say, "I know for a fact", usually have their facts wrong." Be careful of the advice you get at the field.
Finally, the ports on sport engines will bring in more air and fuel if they do not have the angles. Mine do not have angles. The high rpm racing engines do.
Thanks for the questions.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.437RCU1
