rustyrivet
TX, USA Status: offline
Guys, I just finished hooking up a redundant sysem on my table top for testing. I used a JR switch with charge jack, and a Futaba switch with charge jack. I found no problems with a common ground when connecting my accucycler to either one of the charge jacks, and checking the other switch at the battery leads for current: When I charged the Futaba side of the system, and tested the battery leads on the JR, their was no voltage or continuity. (Actually, just in case that sounds confusing, it was the battery leads without a battery on it) The same was true when I ran the charger current throught the JR side of the system. The futaba battery leads were dead as a "door nail". (Where did they come up with that phrase anyway?) So in this case I will have no problems when charging one or both batteries at the same time. Ok now it's time for one of you guys to tell me I checked this improperly, and a problem can still be present. HaHa (Nope. Not this time.)Thanks Again, Randall
