What's Better? Fiberglass Fuselage or All-Balsa Fuselage?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> What's Better? Fiberglass Fuselage or All-Balsa Fuselage?
Page: [1]
Login
What's Better? Fiberglass Fuselage or All-Balsa Fuselage? - 10/25/2006 3:49:47 AM
nitrostaff1
Status: offline
Just wondering which type of fuselage is more preferred by people....so when we put planes into production, we will consider that point too...
_____________________________
--===www.nitroplanes.com===----
       Post #: 1
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 10/25/2006 6:23:13 AM
Kmot
Status: online
Depends on the plane. For scale warbird type planes, fiberglass is preferred because the details can be made in the mold. Such as panel lines, rivets, etc. A balsa fuse is fine, but it is all smooth with a shrink covering applied. So for example, a P-47 is very smooth with no details because it is a balsa fuselage. If it had a fiberglass fuselage it could have the detailing done while it was molded.
DRILL BABY DRILL!!!
(in reply to nitrostaff1)
       Post #: 2
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 10/25/2006 4:34:48 PM
treedog
Status: offline
Kmot i'm sure u didn't mean every last detail as there are others that like to do more or less of their own work but basically right on point
(in reply to Kmot)
       Post #: 3
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 10/25/2006 7:18:18 PM
opjose
Status: offline
As Kmot said, it depends upon the plane.
Build em'', fly em'', crash em'' and build more.
(in reply to treedog)
       Post #: 4
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 10/25/2006 9:57:30 PM
Kmot
Status: online
No, I didn't mean down to every last detail. But at least 'some' detail can be added in the mold. I know there are dedicated "rivet glue ploppers" out there!
DRILL BABY DRILL!!!
(in reply to opjose)
       Post #: 5
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 11/7/2006 3:21:48 AM
EASYTIGER
Status: offline
For scale planes...fiberglass.
The wood ones don't look very good, and don't sell that well.
(in reply to Kmot)
       Post #: 6
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 12/8/2006 10:23:40 PM
rollingrookie
Status: offline
Fiberglass is great until you crack it up!
Go ahead, try it, whats the worst thing that could happen?
(in reply to EASYTIGER)
       Post #: 7
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 12/9/2006 12:35:50 AM
opjose
Status: offline
It's not that hard to repair though.
Color matching is much harder.
(in reply to rollingrookie)
       Post #: 8
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 12/9/2006 3:01:58 AM
jetboy2003
Status: offline
Fiberglass for all warbirds and large scale aerobatic planes (Extas, Caps, Edges, ect..). Especially if you make a pattern type aircraft.
Tricycles are for babies... the little wheel goes in back!!
       Post #: 9
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 3/31/2007 9:46:48 PM
ram3500-RCU
Status: offline
2 cents worth.............I too like fiberglass for scale war birds for simplicity and also the farings are much easier in glass. I do have a scale Jemco P-47 that is wood but covered in brushed chrome Presto. Very good result and the panel lines are better because the panels of Presto are as scale in size and location as I could get them. The rivits were easy as well. But, for giant scale aerobatics, I still think balsa, light ply, stick, and covering is lighter, better, and easier to repair and maintain.
(in reply to jetboy2003)
       Post #: 10
RE: What's Better? Fiberglass Fuselage or All-Balsa Fus... - 4/1/2007 5:14:34 AM
tommytorino
Status: offline
quote:
ORIGINAL: nitrostaff1
On smaller .25 size models I would stick with balsa. Reason being most glass fuses while greater in detail weigh a bunch more then balsa. I, myslef fly mostly electric so weight is a big consideration. A glass fuse weighs more to start, add a few repairs and it's a flying brick.
My Electric World Models Dago Red <glass fuse> is identical to my World Models Candy Man .46 Mustang. The model with the glass fuse is 1lb heavier.
Just my 2 cents from the electric guys.
Tommy D
       Post #: 11
RE: What's Better? Fiberglass Fuselage or All-Balsa Fu... - 4/3/2007 8:31:41 PM
pcsketch
Status: offline
I like building balsa. I like repairing balsa. I like modifying balsa kits. 60% of my enjoying the hobby is in the shop. I'm just a sport flying balsa cuting kind of modeler.
(in reply to tommytorino)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
