YAK 73'' sealing control surfaces
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> YAK 73'' sealing control surfaces
Page: [1]
Login
YAK 73'' sealing control surfaces - 10/25/2006 2:30:55 PM
silversurfer69
Status: offline
I#m not quite sure if i'm getting section 4 step 5 right (sorry not native speaking). Could I also use adhesive tape to seal the hinge line??
Probably someone could be so kind and provide a picture ?
thx,
Frank
       Post #: 1
RE: YAK 73'' sealing control surfaces - 10/25/2006 3:00:35 PM
arobatx
Status: offline
I've used adhesive tape before, but had trouble with it cracking after time. I usually just apply a thin strip of ultracote, if I remember right, on my little Yak it was about 1/2" or 5/8" wide, and the length of the hinged surface. Once cut into a strip, fold it down the center tightly, forming a v-channel out of the strip of ultracote, this way it sits into the bevel of the hinged surface better for you to apply heat with your iron and you are all set. I never have troubles with this method. Good luck and enjoy the plane, it's a winner
_____________________________
Chad
(in reply to silversurfer69)
       Post #: 2
RE: YAK 73'' sealing control surfaces - 12/28/2006 4:31:17 AM
nutherPerson
Status: offline
Scotch tape works well for a season..
(in reply to arobatx)
       Post #: 3
RE: YAK 73'' sealing control surfaces - 12/28/2006 12:51:34 PM
randy racer
Status: offline
i use ultracoat and seal both sides of the hinge line and it looks good and last a long time(longer than most of my planes). i feel this makes the hinge stronger and control serface more effective.
randy
Revver Bro #196
Ford RV Refrigeration Training Center & The RVRN
(in reply to nutherPerson)
       Post #: 4
RE: YAK 73'' sealing control surfaces - 12/28/2006 1:31:25 PM
Zippi
Status: offline
silversurfer69,
Just seal the bottom of the control surface. This is just to stop the air from passing through the control surface and gives a more precise movememt of the control surface. You can use what was mentioned about or clear Monokote. If you ever fly pattern you'll see why the control surfaces need to be sealed. No need to seal both sides.
"It Ain''''t Lookin Good"
http://zippi.50webs.com/index.htm
(in reply to randy racer)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
