bipeguy03
OH, USA Status: offline
I can give you my opinion but it might not be the best. I did'nt run accross any problems in my Ultimate build nor the Suhkoi that I have'nt run into with any other kit. warped spars, bowed Leading edges, and poorly sized sticks, to me it is just kit building. But I have really bad luck any ways so I might just be tolerant to it. All I can say for the Ulitmate is that any headach you may have had durring the build will be made up for the moment the wheels leave the ground. With the suhkoi I havent really noticed any major quality problems other than the Cowl, But about all ABS cowls in kits are junk. The wing is very straight forward and is pretty simple to build. and yes the spars were warped but with carefull planning ang placment I built a near perfect wing. the only flaw was my fualt for not making sure the rib was in the correct spot. As for the fuse it is almost Identical to the Ulimate just Bigger, there is still alot of sanding and trimming to ensure a nice straight fuse, but I still had mine framed in one night. As I said my opinon might not help becuase of my veiws. But to me the problems you have are the same that I encounterd And I just did'nt feel it brought the kit qaulity down
_____________________________
I"M A KIT BUILDER. PERIOD.
