RS4 33 18SS help!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI On-Road >> RS4 33 18SS help!
Page: [1] 2   next >   >>
Login
RS4 33 18SS help! - 10/26/2006 11:34:32 PM
01s0uljah
Status: offline
i ended up picking up this kit today.. and im really stumped on page 9 step 3.. the part A881.. i cant seem to find the 86050c.. ball bearing.. it wasnt preassembled as it stated in the book.. what am i supposed to do withh this thing?!?!
       Post #: 1
RE: RS4 33 18SS help! - 10/26/2006 11:42:20 PM
01s0uljah
Status: offline
edit.. i found out it the spring was under the tight nut.. but what about the hole next to it.. the nut goes in loose and falls out in the hole in the donut.. is it supposed to not be tight/
(in reply to 01s0uljah)
       Post #: 2
RE: RS4 33 18SS help! - 10/27/2006 2:40:42 AM
hpi apollo
Status: offline
i did the same thing, one hole is for the shift point, the other is for the set scerw to hold it on the shaft
_____________________________
95% of statistics are made up on the spot
       Post #: 3
RE: RS4 33 18SS help! - 10/27/2006 4:49:07 AM
01s0uljah
Status: offline
I replaced the hole with the spring and the ball bearing with the black spring.. tighened it as much as possible.. then loosened it 3 rounds...
Now with the gears that it connects to.. im at the step where im about to connect the rear and the front to the gearbox.. i think i could have messed it up... The big gear.. moves only one way.. and locks if i try turning it the other way.. the smaller gear goes both ways.. but doesnt move the axle thing.. its like it doesnt do anything.. and its a little wobbly.. can anyone help me out here? im scared to continue incase i did something wrong..
Check out the pic for more detail...
[URL=http://imageshack.us] [/URL]
Thanks for all the help..
(in reply to hpi apollo)
       Post #: 4
RE: RS4 33 18SS help! - 10/27/2006 1:16:16 PM
hpi apollo
Status: offline
as long as you followed the directions you are fine,t he brake disc will always be a little wobbly, the main spur gear (1st gear) will lock when you move it one way, and the other spur gear (2nd) engages when it is spinning really fast
       Post #: 5
RE: RS4 33 18SS help! - 10/27/2006 3:20:16 PM
buggymangp
Status: offline
thats beacuse theres a one way bearing in there.
all is fine.
i thought the same thing. i just built the car thinking if i did something wrong
i`ll take it apart again. but everything was fine.
       Post #: 6
RE: RS4 33 18SS help! - 10/27/2006 11:16:28 PM
01s0uljah
Status: offline
Okay.. so ive got pretty far today.. got all the axles in and stuff.. and ive got one last question...
when i turn the big gear.. the way that its supposed to.. its suposed to move all 4 wheels.. now ive got a little problem.. when i turn the big gear on the tranny the right way.. i can hold still one of the wheels.. and still have the gear move.. now logically thinking.. when the motor is in and moving.. if something makes the one of the wheel gets stuck.. the motor will still move and not move that stuck wheel... is there something later on that locks everything?
(in reply to buggymangp)
       Post #: 7
RE: RS4 33 18SS help! - 10/28/2006 12:06:12 AM
thedub88
Status: offline
I just checked my 18SS and thats right. When you hold one wheel and turn the gears on the tranny it turns the other wheels.
With the motor in, the small gear on engine and the big gear on the tranny is your first gear. The other gear on the tranny is your second gear and it free wheels, but it doesn't look like it because the grears on the engine are fixed to each other. Once the engine, gears, and tranny get up to speed, the second gear kicks in and the gears for first gear free wheel
both of the gears in the tranny have one way bearings, so while one is driving, the other free wheels
its confusing untill you know how it works
arn't you glad you have to put it together yourself? Imagine trying to rebuild the tranny if you didn't put it together in the first place??
Continue putting the car together it sounds like your doing everything right!!
       Post #: 8
RE: RS4 33 18SS help! - 10/28/2006 1:15:03 AM
01s0uljah
Status: offline
awsome.. great thanks.. i was thinking about going to the LHS for them to take a look.. but it sounds right.. then im gonna continue!
im staring to work on the engine.. i pulled all the way on the pully thing to start it.. would it do any damage if its not connected and me pulling on it?
(in reply to thedub88)
       Post #: 9
RE: RS4 33 18SS help! - 10/28/2006 2:13:37 AM
hpi apollo
Status: offline
DOOOOOOOOO NOT DOOOOOO THAT!!!!! those pull starts screw up really easy, they are not like weed eaters, pull out only 8 inches, no more, please call it a pull start, not a pully thing, if you dont know what something does like that, dont bother it, i screwed my 18ss pull start up, $20 to replace
       Post #: 10
RE: RS4 33 18SS help! - 10/28/2006 11:44:25 AM
01s0uljah
Status: offline
ouch.. i had pulled it a couple times cause i couldnt move the motor with my hands.. and realized that it spun when you pulled it.. Ive just about got everything set up.. i just need to find a place to buy a good cheap radio... then i can start this baby up.. thank you guys for all your help...
Im still a little iffy on whether i did the front and back differentials (? i dont know what they are called, the front and back thing holding the axle to spin the wheels).. When i spin one of the back wheels clock wise.. th other back wheel spins counterclock wise.. is this right?
       Post #: 11
RE: RS4 33 18SS help! - 10/28/2006 2:11:25 PM
thedub88
Status: offline
quote:
ORIGINAL: 01s0uljah
yes its called a defferential, it's supposed to turn the opposite way when you turn the other wheel.
First let me say you MUST break in the engine before you can use the car (do a serch on this site "engine break in" look for the heat cycle method)
Before you even pull on the pull start for the first time your supposed to put a few drops of "after run oil" under the glo plug and in the carb. Too late but probably no harm done.
Do you have a glo starter? if not get a rechargeable with a meter.
I hear this all the time - "I need a good cheep radio" Its like saying hot and cold. You cant have both. Good radios are expensive and cheep radios are crap.
Get a good computer radio, ya I know everyone has a budget, but buying a cheep radio now will only make you buy another in a few years. Do you want to buy two crap radios or one good one? Im not saying spend $1000 but don't skimp
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCHA7**&P=0
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGAG4**&P=0
       Post #: 12
RE: RS4 33 18SS help! - 10/28/2006 9:05:46 PM
01s0uljah
Status: offline
I ended up getting an Acoms 4 channel remote.. not smart of me.. oh well.. anyways.. i need some more help guys..
I decided to be an idiot.. and mess around with the motor.. i turned some of the valves.. both of them to be exact.. now i want to change it back to the stock settings... does anybody know what the stock settings are for the throttle valve and the bigger one? thanks!
       Post #: 13
RE: RS4 33 18SS help! - 10/28/2006 10:48:52 PM
thedub88
Status: offline
is the acoms a pistol or stick style? what did you pay? four channel radios are usualy only for aircraft.
I'm not sure what the stock needle setting are. Mine are differant because of different factors such as nitro content, type of air cleaner, outside temp.
       Post #: 14
RE: RS4 33 18SS help! - 10/29/2006 12:02:22 AM
01s0uljah
Status: offline
The Acoms I got was 150 Canadian.. everything is so much more expensive up here.. anyways.. it came with 3 servos.. im planning to do a mod for the third channel for led lights..
Overall.. i think the build quality of the radio is garbage.. it feels cheap..
anyways.. i have my whole car built.. Im just in need of the stock setting for the Low Speed Needle and the High Speed needle.. Can anybody help me out?
