RE: Purple Brushless Electric Ultimate BiPe
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: Purple Brushless Electric Ultimate BiPe
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Purple Brushless Electric Ultimate BiPe - 12/8/2006 8:20:22 PM
rev
Status: offline
I"am using the motor,esc set up on a mini stick now. It flys good but vert is limited. It has enough power to do rolling harriers, snaps and great flat spins.
_____________________________
RC pilots - We are outstanding in the field !!
(in reply to opjose)
       Post #: 26
RE: Purple Brushless Electric Ultimate BiPe - 12/9/2006 11:17:43 PM
KWJ48
Status: offline
Here's some pics of my build. I haven't flown it yet , but I used hs 55 servos, this ESC, and this motor. The motor is just a bit more kv than the park 480 so it should do well.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to rev)
       Post #: 27
RE: Purple Brushless Electric Ultimate BiPe - 12/10/2006 12:26:50 AM
rev
Status: offline
It looks like it is build fairly good, by your pics.
(in reply to KWJ48)
       Post #: 28
RE: Purple Brushless Electric Ultimate BiPe - 12/11/2006 12:15:26 AM
opjose
Status: offline
quote:
ORIGINAL: KWJ48
Hah I just put in a motor with similiar specs.
Now the BiPe flies with about 40% throttle and does go straight up almost unlimited.
My flight times with my 2200mAh batteries have been cut to about 14 minutes though, whereas the other motor was giving me about 30 minutes... but it was far more anemic.
Make sure your ESC will handle 20amps+.
My 15/25 amp ESC is really borderline with that motor.... I'm going to change it out too.
< Message edited by opjose -- 12/11/2006 12:37:17 AM >
Build em'', fly em'', crash em'' and build more.
(in reply to KWJ48)
       Post #: 29
RE: Purple Brushless Electric Ultimate BiPe - 12/11/2006 12:23:47 AM
rev
Status: offline
What motor?
       Post #: 30
RE: Purple Brushless Electric Ultimate BiPe - 12/11/2006 12:39:37 AM
opjose
Status: offline
I upgraded to a motor almost identical to this one CLICK ME! which is what KWJ48 used.
It draws quite a bit from the ESC even when underpropping the plane.
(in reply to rev)
       Post #: 31
RE: Purple Brushless Electric Ultimate BiPe - 12/11/2006 12:52:51 AM
rev
Status: offline
What size and make prop are you using?
       Post #: 32
RE: Purple Brushless Electric Ultimate BiPe - 12/11/2006 12:53:59 AM
KWJ48
Status: offline
The esc is a 35 amp, so it should be ok. I found a 10x5e and a 10x7e at my hobby shop to try. I also ordered a couple of 9'' e props to try. opjose what prop are you using with that motor ?
       Post #: 33
RE: Purple Brushless Electric Ultimate BiPe - 12/11/2006 3:12:28 AM
opjose
Status: offline
I flew it today with a 9x6E prop.
The plane was nice and fast with this, flying constant level at about 35-40% throttle.
I did note a LOT of torque however as I kept trimming the ailerons throughout the flight.
The small wings of the BiPE may be coming into play.
I'm using the Tower Pro ESC that is rated at 15A continuous 25A burst.
The ESC was warm, approaching HOT, one of my batteries got very warm, indicating that I was reaching the battery's maximum draw. Another identical pack stayed cool throughout the flight...
I'm going to order higher draw batteries for this plane... (check out the ones on NP's web page, they are pretty good for the price, I have four of them which I use for my Super Sportster EP in a 3S2P configuration... 4400mAh...).
I brought the plane in after 12 minutes on each 2000mAh pack today, as I did not know when the cutoff would kick in... I haven't timed the duration yet.
(in reply to KWJ48)
       Post #: 34
RE: Purple Brushless Electric Ultimate BiPe - 12/11/2006 8:00:20 PM
KWJ48
Status: offline
Well I finally maidened my ultimate today. I only ran 2 packs (TP 2100's) through it though. A couple clicks and the plane flew great. I flew with a 10x5e apc prop and it seemed to have plenty of power. It slowed down pretty good too. Run times were roughly 10-12 min. I didn't throw nothing hard at it. I did notice (with my set-up) on tight loops it liked to snap out at the top. The knife edge is pretty good too. I flew mainly at 1/2 throttle (full throttle a couple of times) and the ESC and battery were pretty warm, but I had no cut outs. I need to get a watt meter so I can tell how much power I'm pulling. I think I need larger arms for my aileron servos, as my roll rate was kind of slow, but still not bad, compared to my rudder and elevator. On high rates I have as much as I can get on all the tail feathers, and it seems to flip the plane around pretty good. On the second landing I came down kind of hard, but no damage other than the landing gear was bent some. I think I'm gonna put some checkers on the bottom, as this plane can get small quick if you don't keep it close. This is a great little bipe.
       Post #: 35
RE: Purple Brushless Electric Ultimate BiPe - 12/11/2006 11:21:21 PM
rev
Status: offline
My plane should be here tomorrow with any luck. I have a extra motor and esc since my mini stick kissed the ground yesterday.
(in reply to KWJ48)
       Post #: 36
RE: Purple Brushless Electric Ultimate BiPe - 12/12/2006 1:44:29 AM
opjose
Status: offline
quote:
ORIGINAL: KWJ48
This is quite common with the Ultimates... There is a range of elevator throw where this will happen.
Either INCREASE or DECREASE the throw until it stops.
Increasing causes both wings to stall equally stopping the out of round... decreasing lessens the stall with the same effect.
I increase mine to the point that the high rates stop going out of round on the tight loops and the low rates give me big unstalled loops.
(in reply to KWJ48)
       Post #: 37
RE: Purple Brushless Electric Ultimate BiPe - 1/7/2007 1:58:38 AM
rev
Status: offline
The purple bird is ready to fly- once the weather coperates. I replaced some of the hardware, wheel axle bolts were to short . and it balances tail heavy at the rec. c.g. .
       Post #: 38
RE: Purple Brushless Electric Ultimate BiPe - 1/7/2007 3:14:53 AM
opjose
Status: offline
At the recommended C.G. mine still has a tendancy to climb at 60% throttle so don't be afraid to be a little nose heavy.
I have a 2200mAh battery in mine.
(in reply to rev)
